PRODUCT DATASHEET
Eva series
Ordering number C12041
Description
C12041_Eva-S-XM
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Eva
Lens
XM-L
Transparent
35 mm
16.4 mm
Round
PMMA
Ready
FWHM
Efficiency
cd/lm
Gerber File
13 degrees
94 %
Available
Outer flange can be secured in fixture for hardware-free attachm
Ordering number C10684
Description
C10684_Eva-XM-D
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Eva
Lens
XM-L
Transparent
35 mm
16.4 mm
Round
PMMA
Ready
FWHM
Efficiency
cd/lm
Gerber File
16 degrees
91 %
Available
Ordering number C10685
Description
C10685_Eva-XM-M
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Eva
Lens
XM-L
Transparent
35 mm
16.4 mm
Round
PMMA
Ready
FWHM
Efficiency
cd/lm
Gerber File
24 degrees
88 %
Available
Ordering number C10686
Description
C10686_Eva-XM-W
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Eva
Lens
XM-L
Transparent
35 mm
16.4 mm
Round
PMMA
Ready
FWHM
Efficiency
cd/lm
Gerber File
40 degrees
79 %
Available
December 1st 2011 12:16 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Eva series
Ordering number C10909
Description
C10909_Eva-XM-WW
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Eva
Lens
XM-L
Transparent
35 mm
16.4 mm
Round
PMMA
Ready
FWHM
Efficiency
cd/lm
Gerber File
64 degrees
77 %
Available
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
December 1st 2011 12:16 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
PRODUCT DATASHEET
Eva series
GENERAL INFORMATION
- Product series especially designed & optimized for XM-L series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220
degrees of Fahrenheit). Allows use of high current and temperature conditions.
Please find more information about used material from below:
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf
December 1st 2011 12:16 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
很抱歉,暂时无法提供与“C10684_EVA-XM-D”相匹配的价格&库存,您可以联系我们找货
