C12481_MIRELLA-50-M-PIN
    LEDIL(芬兰)
    REFLECTOR 1POS 49.9MM RND 24MM
C12481_MIRELLA-50-M-PIN 数据手册
PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN MIRELLA-50-M-PIN ~30° medium beam SPECIFICATION: Dimensions Ø 49.9 mm Height 23.9 mm Fastening pin ROHS compliant yes MATERIALS: Component Type Material Colour MIRELLA-50-M-PIN Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C12481_MIRELLA-50-M-PIN » Box size: 480 x 280 x 300 mm Qty in box 336 MOQ MPQ 112 28 Box weight (kg) 3.1 Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED SM4 FWHM / FWTM 35.0° / 73.0° Efficiency 78 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED SM4 FWHM / FWTM 29.0° / 68.0° Efficiency 80 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED MHB-A/B FWHM / FWTM 34.0° / 78.0° Efficiency 83 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED MHB-A/B FWHM / FWTM 28.0° / 80.0° Efficiency 88 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MHB-A/B FWHM / FWTM 35.0° / 76.0° Efficiency 83 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XHP50 FWHM / FWTM 37.0° / 78.0° Efficiency 83 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED XHP50 FWHM / FWTM 32.0° / 76.0° Efficiency 85 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED XHP50 FWHM / FWTM 25.0° / 77.0° Efficiency 90 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP50 FWHM / FWTM 32.0° / 74.0° Efficiency 86 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED XM-L FWHM / FWTM 28.0° / 72.0° Efficiency 84 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED XM-L FWHM / FWTM 35.0° / 76.0° Efficiency 80 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XM-L FWHM / FWTM 24.0° / 56.0° Efficiency 89 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED XM-L RGBW (XMLCTW) FWHM / FWTM 37.0° / 76.0° Efficiency 83 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL LED XM-L2 FWHM / FWTM 33.0° / 74.0° Efficiency 82 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XM-L2 FWHM / FWTM 22.0° / 58.0° Efficiency 91 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED XP-G FWHM / FWTM 34.0° / 74.0° Efficiency 81 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XP-G FWHM / FWTM 24.0° / 53.0° Efficiency 86 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G FWHM / FWTM 24.0° / 68.0° Efficiency 83 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED XP-G2 FWHM / FWTM 30.0° / 74.0° Efficiency 83 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XP-G2 FWHM / FWTM 22.0° / 76.0° Efficiency 88 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HI FWHM / FWTM 17.0° / 48.0° Efficiency 88 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED XT-E FWHM / FWTM 23.0° / 51.0° Efficiency 85 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 22.0° / 64.0° Efficiency 81 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED XT-E FWHM / FWTM 32.0° / 73.0° Efficiency 78 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED LUXEON 5050 Round LES FWHM / FWTM 22.0° / 59.0° Efficiency 90 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON A FWHM / FWTM 34.0° / 75.0° Efficiency 80 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED LUXEON A FWHM / FWTM 24.0° / 69.0° Efficiency 84 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED LUXEON A FWHM / FWTM 22.0° / 52.0° Efficiency 87 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON C FWHM / FWTM 39.0° / 79.0° Efficiency 74 % Peak intensity 1.2 cd/lm LEDs/each optic 4 Light colour/type RGBW Required components: C13723_MIRELLA-RZL LED LUXEON M/MX FWHM / FWTM 33.0° / 74.0° Efficiency 84 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED LUXEON M/MX FWHM / FWTM 24.0° / 63.0° Efficiency 87 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON M/MX FWHM / FWTM 38.0° / 78.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED LUXEON MZ FWHM / FWTM 20.0° / 47.0° Efficiency 88 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED LUXEON MZ FWHM / FWTM 27.0° / 69.0° Efficiency 84 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED LUXEON Z FWHM / FWTM 31.0° / 71.0° Efficiency 83 % Peak intensity 1.7 cd/lm LEDs/each optic 4 Light colour/type RGBW Required components: C13723_MIRELLA-RZL LED NS9x383 FWHM / FWTM 32.0° / 74.0° Efficiency 83 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED NS9x383 FWHM / FWTM 24.0° / 78.0° Efficiency 88 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NV4x144A FWHM / FWTM 27.0° / 73.0° Efficiency 89 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S8 FWHM / FWTM 22.0° / 58.0° Efficiency 88 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED Duris S8 FWHM / FWTM 26.0° / 70.0° Efficiency 84 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED Duris S8 FWHM / FWTM 28.0° / 69.0° Efficiency 84 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED OSLON Square EC FWHM / FWTM 22.0° / 49.0° Efficiency 84 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 32.0° / 75.0° Efficiency 79 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED OSLON Square EC FWHM / FWTM 22.0° / 67.0° Efficiency 83 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED Ostar-SMT RGB FWHM / FWTM 34.0° / 74.0° Efficiency 83 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (MEASURED): LED LH508A FWHM / FWTM 24.0° / 78.0° Efficiency 88 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED F50360 (RGB) FWHM / FWTM 33.0° / 76.0° Efficiency 82 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (SIMULATED): LED XHP35 HD FWHM / FWTM 28.0° / 77.0° Efficiency 92 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5258 FWHM / FWTM 23.0° / 45.0° Efficiency 91 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 7070 FWHM / FWTM 31.0° / 72.0° Efficiency 88 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 26.0° / 63.0° Efficiency 91 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 7070 FWHM / FWTM 29.0° / 70.0° Efficiency 87 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED LH351D FWHM / FWTM 26.0° / 54.0° Efficiency 90 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN OPTICAL RESULTS (SIMULATED): LED Z8Y22P FWHM / FWTM 19.0° / 44.0° Efficiency 89 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/22 PRODUCT DATASHEET C12481_MIRELLA-50-M-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/22
C12481_MIRELLA-50-M-PIN 价格&库存
很抱歉,暂时无法提供与“C12481_MIRELLA-50-M-PIN”相匹配的价格&库存,您可以联系我们找货
