CP15776_CARMEN-W-C
CP15776_CARMEN-W-C
    LEDIL(芬兰)
    LENSROUND69.5MMWIDEDIFFUSED
CP15776_CARMEN-W-C 数据手册
PRODUCT DATASHEET CP15776_CARMEN-W-C CARMEN-W-C ~55° wide beam. Assembly with holder C compatible with LEDiL HEKLA. SPECIFICATION: Dimensions Height Ø 69.5 mm 41.5 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length CARMEN-W Single lens PMMA clear 66.4 CARMEN-HLD-C Holder PC black 69.5 ORDERING INFORMATION: Component CP15776_CARMEN-W-C » Box size: 476 x 273 x 292 mm Qty in box Single lens 150 MOQ MPQ 150 15 Box weight (kg) 4.5 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/23 PRODUCT DATASHEET CP15776_CARMEN-W-C See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED V4 HD Gen 7 FWHM / FWTM 52.0° / 72.0° Efficiency 85 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15253_HEKLA-SOCKET-A LED V6 HD Gen 7 FWHM / FWTM 52.0° / 73.0° Efficiency 83 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED V9 HD Gen7 FWHM / FWTM 52.0° / 74.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED VERO10 FWHM / FWTM 55.0° / 78.0° Efficiency 83 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Vesta DTW 13mm (21W) FWHM / FWTM 64.0° / 84.0° Efficiency 70 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 491 Typ L8 LED Vesta DTW 9mm (4W/6W/12W) FWHM / FWTM 48.0° / 71.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 490 Typ L8 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED Vesta TW 6mm DP FWHM / FWTM 50.0° / 72.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 504 Typ L8 LED Vesta TW 9mm (12W) CSP FWHM / FWTM 50.0° / 73.0° Efficiency 75 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K LED Vesta TW 9mm (9W) DP FWHM / FWTM 52.0° / 75.0° Efficiency 77 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 489 Typ L8 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED CLC020 Series (Dim-To-Warm) FWHM / FWTM 48.0° / 72.0° Efficiency 75 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K LED CLL02x/CLU02x (LES10) FWHM / FWTM 54.0° / 78.0° Efficiency 82 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED CLU700/701/702/703 FWHM / FWTM 52.0° / 74.0° Efficiency 85 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED CLU710/711 FWHM / FWTM 52.0° / 75.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I LED CLU7A2/7A3 FWHM / FWTM 54.0° / 73.0° Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED CLU7B2 FWHM / FWTM 53.0° / 73.0° Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED LCN-C01B (Tunable White) FWHM / FWTM 49.0° / 72.0° Efficiency 74 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K LED CMA1516 FWHM / FWTM 55.0° / 78.0° Efficiency 82 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15256_HEKLA-SOCKET-D LED LUXEON CX Plus CoB L08 (Gen2) FWHM / FWTM 64.0° / 85.0° Efficiency 71 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 637a Hekla Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1202HD FWHM / FWTM 52.0° / 74.0° Efficiency 82 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15848_HEKLA-SOCKET-G LED LUXEON CoB 1204HD FWHM / FWTM 53.0° / 75.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15858_HEKLA-SOCKET-H LED LUXEON CoB 1205HD FWHM / FWTM 56.0° / 79.0° Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15858_HEKLA-SOCKET-H Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED LUXEON CX Plus CoB - HD S01H4 FWHM / FWTM 51.0° / 73.0° Efficiency 82 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 634c Hekla LED LUXEON CX Plus CoB - HD S02H6 FWHM / FWTM 51.0° / 73.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 634c Hekla LED LUXEON CX Plus CoB - HD S04H9 FWHM / FWTM 53.0° / 76.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 634c Hekla Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED LUXEON CX Plus CoB L04 / L05 (Gen2) FWHM / FWTM 57.0° / 80.0° Efficiency 76 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 637a Hekla LED LUXEON CX Plus CoB M02 / M03 (Gen2) FWHM / FWTM 52.0° / 75.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 641a Hekla LED LUXEON CX Plus CoB S01 (Gen2) FWHM / FWTM 51.0° / 72.0° Efficiency 83 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 634c Hekla Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED CDM-6 (Dim-To-Warm) FWHM / FWTM 51.0° / 73.0° Efficiency 78 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 490 Typ L8 LED CDM-9 (Dim-To-Warm) FWHM / FWTM 53.0° / 75.0° Efficiency 77 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 490 Typ L8 LED CTM-9 (Tunable White) FWHM / FWTM 53.0° / 75.0° Efficiency 77 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 495 Typ L8 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED CxM-11 (19x19) FWHM / FWTM 58.0° / 81.0° Efficiency 76 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I LED CXM-3 FWHM / FWTM 53.0° / 72.0° Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED CXM-4 FWHM / FWTM 52.0° / 73.0° Efficiency 85 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED CxM-9 (13.5x13.5) FWHM / FWTM 53.0° / 77.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED NJCWL024Z-V1MT: COB L-Type Tunable White FWHM / FWTM 48.0° / 71.0° Efficiency 76 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 497 Typ L8 LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 53.0° / 76.0° Efficiency 74 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 498 Typ L8 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED Fortimo SLM L09 CoB FWHM / FWTM 54.0° / 76.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15858_HEKLA-SOCKET-H LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 55.0° / 78.0° Efficiency 82 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED LC010C G2 FWHM / FWTM 52.0° / 74.0° Efficiency 84 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED LC010T (Tunable White) FWHM / FWTM 51.0° / 74.0° Efficiency 76 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 501 Typ L8 LED LC020C G2 FWHM / FWTM 52.0° / 75.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I LED MJT COB LES 6 FWHM / FWTM 52.0° / 73.0° Efficiency 82 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED MJT COB LES 9.8 FWHM / FWTM 54.0° / 77.0° Efficiency 79 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED SLE G7 LES09 FWHM / FWTM 53.0° / 77.0° Efficiency 83 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED SLE G7 LES13 FWHM / FWTM 63.0° / 83.0° Efficiency 74 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (MEASURED): LED XOB 6 mm FWHM / FWTM 53.0° / 74.0° Efficiency 83 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED XOB 9.8 mm FWHM / FWTM 53.0° / 77.0° Efficiency 83 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED XTM - 19mm LES FWHM / FWTM 64.0° / 91.0° Efficiency 66 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16058_XTM-ADAPTER-50-C Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (SIMULATED): LED VERO10 FWHM / FWTM 50.7° / 72.0° Efficiency 0% Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15616_HEKLA-SOCKET-F LED VERO13 FWHM / FWTM 52.0° / 76.0° Efficiency 72 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K LED CLL03x/CLU03x FWHM / FWTM 63.0° / 85.0° Efficiency 66 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (SIMULATED): LED CMA1825 FWHM / FWTM 59.0° / 80.0° Efficiency 77 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CMA1840 FWHM / FWTM 62.0° / 87.0° Efficiency 72 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CMT14xx FWHM / FWTM 52.0° / 73.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (SIMULATED): LED CXA/B 15xx FWHM / FWTM 53.5° / 72.5° Efficiency 0% Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15256_HEKLA-SOCKET-D LED CxM-6 (13.5x13.5) FWHM / FWTM 52.0° / 69.0° Efficiency 83 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C LED COB T-Type FWHM / FWTM 54.0° / 69.0° Efficiency 84 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15848_HEKLA-SOCKET-G Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/23 PRODUCT DATASHEET CP15776_CARMEN-W-C OPTICAL RESULTS (SIMULATED): LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 52.0° / 74.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 55.0° / 75.0° Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C LED LC010C FWHM / FWTM 51.0° / 68.0° Efficiency 85 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/23 PRODUCT DATASHEET CP15776_CARMEN-W-C GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/23
CP15776_CARMEN-W-C 价格&库存
很抱歉,暂时无法提供与“CP15776_CARMEN-W-C”相匹配的价格&库存,您可以联系我们找货
CP15776_CARMEN-W-C
    CP15776_CARMEN-W-C
      CP15776_CARMEN-W-C
