CS15767_HB-2X2MX-8-M
    LEDIL(芬兰)
CS15767_HB-2X2MX-8-M 数据手册
PRODUCT DATASHEET CS15767_HB-2X2MX-8-M HB-2X2MX-8-M ~30° wide beam. New revision. SPECIFICATION: Dimensions Height Fastening 90.0 x 90.0 mm 16.4 mm screw Ingress protection classes ROHS compliant IP67 yes MATERIALS: Component Type Material Colour HB-2X2MX-8-M Multi-lens PMMA clear STRADA-2X2MX-8-SEAL Seal Silicone clear Finish ORDERING INFORMATION: Component CS15767_HB-2X2MX-8-M » Box size: 480 x 280 x 300 mm Qty in box Multi-lens 156 MOQ MPQ 52 52 Box weight (kg) 8.3 Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 31.0° / 101.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 441 Typ 2x2MX HV LED LUXEON M/MX FWHM / FWTM 25.0° / 52.0° Efficiency 94 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-7070 (L224-xxxx004MLU010) FWHM / FWTM 26.0° / 61.0° Efficiency 94 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM SC16 (LH181B) FWHM / FWTM 25.0° / 64.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M OPTICAL RESULTS (MEASURED): LED XLE-S22C4XD16 (XD16) FWHM / FWTM 23.0° / 50.0° Efficiency 93 % Peak intensity 3.3 cd/lm LEDs/each optic 4 Light colour White Required components: LED WICOP 5050 FWHM / FWTM 24.0° / 51.0° Efficiency 95 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM 27.0° / 63.0° Efficiency 91 % Peak intensity 2.1 cd/lm LEDs/each optic 4 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M OPTICAL RESULTS (SIMULATED): LED Bridgelux SMD 5050 FWHM / FWTM 19.0° / 43.0° Efficiency 94 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED CLU700/701/702/703 FWHM / FWTM 22.0° / 58.0° Efficiency 92 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 434 Typ 2x2MX HV LED CMA1303 FWHM / FWTM 16.0° / 44.0° Efficiency 96 % Peak intensity 5.7 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 448 Typ 2x2MX HV LED XHP35 HD FWHM / FWTM 17.0° / 34.0° Efficiency 94 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M OPTICAL RESULTS (SIMULATED): LED XHP35 HI FWHM / FWTM 14.0° / 30.0° Efficiency 94 % Peak intensity 9.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 22.0° / 44.0° Efficiency 94 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70.2 FWHM / FWTM 30.0° / 62.0° Efficiency 91 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XHP70.3 HD FWHM / FWTM 28.0° / 56.0° Efficiency 96 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M OPTICAL RESULTS (SIMULATED): LED LUXEON 7070 FWHM / FWTM 24.0° / 58.0° Efficiency 96 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED MP 7070 FWHM / FWTM 22.0° / 52.0° Efficiency 97 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFT-40-WCS FWHM / FWTM 10.0° / 20.0° Efficiency 97 % Peak intensity 17.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFT-70X-WCS FWHM / FWTM 12.0° / 26.0° Efficiency 97 % Peak intensity 12.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M OPTICAL RESULTS (SIMULATED): LED NF2x757G FWHM / FWTM 34.0° / 66.0 + 67.0° Efficiency 97 % Peak intensity 2 cd/lm LEDs/each optic 4 Light colour White Required components: LED NFMW48xA FWHM / FWTM 19.0° / 42.0° Efficiency 94 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM 16.0° / 34.0° Efficiency 97 % Peak intensity 7.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 14.0° / 28.0° Efficiency 94 % Peak intensity 10.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M OPTICAL RESULTS (SIMULATED): LED Duris S10 FWHM / FWTM 20.0° / 43.0° Efficiency 94 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ C 2424 FWHM / FWTM 28.0° / 52.0° Efficiency 97 % Peak intensity 3.3 cd/lm LEDs/each optic 4 Light colour White Required components: LED LH181B FWHM / FWTM 14.0° / 28.0° Efficiency 96 % Peak intensity 11 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH231B FWHM / FWTM 14.0° / 30.0° Efficiency 96 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET CS15767_HB-2X2MX-8-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 15/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
CS15767_HB-2X2MX-8-M 价格&库存
很抱歉,暂时无法提供与“CS15767_HB-2X2MX-8-M”相匹配的价格&库存,您可以联系我们找货
