F12985_CRYSTAL-MINE
F12985_CRYSTAL-MINE
    LEDIL(芬兰)
F12985_CRYSTAL-MINE 数据手册
PRODUCT DATASHEET F12985_CRYSTAL-MINE CRYSTAL-MINE ~4.9° spot beam especially designed for mining headlamps SPECIFICATION: Dimensions Height Ø 46.8 mm 27.4 mm Fastening snaps ROHS compliant yes MATERIALS: Component Type Material Colour CRYSTAL-MINE Single lens PMMA clear Finish ORDERING INFORMATION: Component F12985_CRYSTAL-MINE » Box size: 480 x 280 x 300 mm Qty in box 288 MOQ MPQ 64 32 Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.1 1/7 PRODUCT DATASHEET F12985_CRYSTAL-MINE See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET F12985_CRYSTAL-MINE OPTICAL RESULTS (MEASURED): LED XM-L2 FWHM / FWTM 6.9° / 15.0° Efficiency 90 % Peak intensity 35 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 3.0° / 7.9° Efficiency 92 % Peak intensity 96 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 4.7° / 10.5° Efficiency 90 % Peak intensity 66.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 4.6° / 12.0° Efficiency 90 % Peak intensity 65.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET F12985_CRYSTAL-MINE OPTICAL RESULTS (MEASURED): LED LUXEON A FWHM / FWTM 4.9° / 13.0° Efficiency 89 % Peak intensity 58.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 4.9° / 13.0° Efficiency 89 % Peak intensity 55.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 5.0° / 12.6° Efficiency 94 % Peak intensity 50.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19B FWHM / FWTM 3.6° / 12.0° Efficiency 90 % Peak intensity 73.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET F12985_CRYSTAL-MINE OPTICAL RESULTS (MEASURED): LED LH351B FWHM / FWTM 5.1° / 13.0° Efficiency 90 % Peak intensity 51.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 4.2° / 10.0° Efficiency 90 % Peak intensity 71.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET F12985_CRYSTAL-MINE OPTICAL RESULTS (SIMULATED): LED LUXEON CZ FWHM / FWTM 4.0° / 10.0° Efficiency 95 % Peak intensity 98.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET F12985_CRYSTAL-MINE GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
F12985_CRYSTAL-MINE
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗的特性,适用于高速光耦应用。
3. 引脚分配:EL817共有6个引脚,分别为A(发光二极管阳极)、KA(发光二极管阴极)、COL(集电极)、EMT(发射极)、GND(地)和VCC(电源)。
4. 参数特性:EL817的主要参数包括工作温度范围(-40℃至+85℃)、输入电流(最大20mA)、输出电流(最大50mA)等。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:EL817广泛应用于通信设备、工业控制系统、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 3.9mm。
F12985_CRYSTAL-MINE 价格&库存
很抱歉,暂时无法提供与“F12985_CRYSTAL-MINE”相匹配的价格&库存,您可以联系我们找货
F12985_CRYSTAL-MINE
  • 1+41.02465
  • 8+36.47301
  • 64+31.90939
库存:56
F12985_CRYSTAL-MINE
  • 1+44.146021+5.69520
  • 8+39.240918+5.06240
  • 64+34.3358064+4.42960
库存:56
F12985_CRYSTAL-MINE
