C12083_BROOKE-SCR-M
C12083_BROOKE-SCR-M
    LEDIL(芬兰)
    REFLECTR 1POS 45MM RND OD 20.2MM
C12083_BROOKE-SCR-M 数据手册
PRODUCT DATASHEET Brooke-SCR series Ordering number C12083 Description C12083_Brooke-SCR-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Brooke Reflector BXRA-C0400 Metal 45 mm 20.2 mm Round PC Screw, glue Ready FWHM Efficiency cd/lm Gerber File 23 degrees Available FWHM Efficiency cd/lm Gerber File 42 degrees Available Ordering number C12084 Description C12084_Brooke-SCR-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Brooke Reflector BXRA-C0400 Metal 45 mm 20.2 mm Round PC Screw, glue Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. February 13th 2012 16:32 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Brooke-SCR series GENERAL INFORMATION - Product series especially designed & optimized for BXRA-C0400 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue options. http://www.ledil.com/datasheets/DataSheet_GLUES.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the glue. NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. February 13th 2012 16:32 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001
C12083_BROOKE-SCR-M 价格&库存
很抱歉,暂时无法提供与“C12083_BROOKE-SCR-M”相匹配的价格&库存,您可以联系我们找货
