C13085_MIRELLA-50-S-PF
    LEDIL(芬兰)
    REFLECTOR RND 1POS 49.9MM 24MM
C13085_MIRELLA-50-S-PF 数据手册
PRODUCT DATASHEET C13085_MIRELLA-50-S-PF MIRELLA-50-S-PF ~15° spot beam SPECIFICATION: Dimensions Ø 49.9 mm Height 24 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour MIRELLA-50-S-PF Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C13085_MIRELLA-50-S-PF » Box size: 480 x 280 x 300 mm Qty in box 336 MOQ MPQ 112 28 Box weight (kg) 3.0 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED V10 Gen7 FWHM / FWTM 21.0° / 61.0° Efficiency 91 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 486 Typ L1 LED V10 Gen7 FWHM / FWTM 26.0° / 66.0° Efficiency 79 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL LED V10 Gen7 FWHM / FWTM 21.0° / 61.0° Efficiency 81 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL LED V6 Gen6 FWHM / FWTM 18.0° / 52.0° Efficiency 73 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 460 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED V6 Gen6 FWHM / FWTM 15.0° / 33.0° Efficiency 84 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED V6 Gen6 FWHM / FWTM 12.0° / 25.0° Efficiency 90 % Peak intensity 8.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED V6 Gen6 FWHM / FWTM 13.0° / 26.0° Efficiency 84 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED V8 Gen6 FWHM / FWTM 16.0° / 36.0° Efficiency 84 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED V8 Gen6 FWHM / FWTM 15.0° / 34.0° Efficiency 90 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED V8 Gen6 FWHM / FWTM 20.0° / 62.0° Efficiency 71 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 460 Typ L1 LED V8 Gen6 FWHM / FWTM 18.0° / 44.0° Efficiency 85 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED VERO10 FWHM / FWTM 20.0° / 57.0° Efficiency 88 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13708_PF-SOCKET-VERO10 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED VERO10 FWHM / FWTM 23.0° / 63.0° Efficiency 83 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13708_PF-SOCKET-VERO10 C12479_MIRELLA-DL LED VERO10 FWHM / FWTM 23.0° / 63.0° Efficiency 83 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13708_PF-SOCKET-VERO10 C13333_MIRELLA-CL LED VERO13 FWHM / FWTM 28.0° / 68.0° Efficiency 84 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL LED VERO13 FWHM / FWTM 25.0° / 69.0° Efficiency 89 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED VERO13 FWHM / FWTM 26.0° / 67.0° Efficiency 83 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL LED Xenio Point 13mm FWHM / FWTM 31.0° / 70.0° Efficiency 81 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL LED Xenio Point 13mm FWHM / FWTM 26.0° / 69.0° Efficiency 87 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 LED Xenio Point 13mm FWHM / FWTM 27.0° / 67.0° Efficiency 83 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CLL01x FWHM / FWTM 13.0° / 27.0° Efficiency 84 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED CLL01x FWHM / FWTM 15.0° / 32.0° Efficiency 84 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED CLL01x FWHM / FWTM 14.0° / 27.0° Efficiency 88 % Peak intensity 7.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED CLL02x/CLU02x (LES10) FWHM / FWTM 27.0° / 67.0° Efficiency 77 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 21.0° / 63.0° Efficiency 84 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 LED CLL02x/CLU02x (LES10) FWHM / FWTM 20.0° / 61.0° Efficiency 80 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED CLL02x/CLU02x (LES10) FWHM / FWTM 20.0° / 54.0° Efficiency 83 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED CLL02x/CLU02x (LES10) FWHM / FWTM 19.0° / 46.0° Efficiency 87 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 25.0° / 64.0° Efficiency % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED CLL02x/CLU02x (LES10) FWHM / FWTM 18.0° / 43.0° Efficiency 83 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED CLU700/701/702/703 FWHM / FWTM 23.0° / 61.0° Efficiency 82 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED CLU700/701/702/703 FWHM / FWTM 19.0° / 47.0° Efficiency 84 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CLU700/701/702/703 FWHM / FWTM 14.0° / 40.0° Efficiency 79 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED CLU700/701/702/703 FWHM / FWTM 17.0° / 47.0° Efficiency 82 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED CLU700/701/702/703 FWHM / FWTM 13.0° / 30.0° Efficiency 83 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED CLU700/701/702/703 FWHM / FWTM 20.0° / 58.0° Efficiency 79 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CLU700/701/702/703 FWHM / FWTM 13.0° / 29.0° Efficiency 89 % Peak intensity 7.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED CLU720/721/723 FWHM / FWTM 29.0° / 69.0° Efficiency 75 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 433 Typ L1 LED CLU720/721/723 FWHM / FWTM 23.0° / 67.0° Efficiency 82 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 433 Typ L1 LED CLU720/721/723 FWHM / FWTM 23.0° / 64.0° Efficiency 77 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 433 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CXA/B 13xx FWHM / FWTM 15.0° / 36.0° Efficiency 81 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED CXA/B 13xx FWHM / FWTM 12.0° / 25.0° Efficiency 87 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED CXA/B 13xx FWHM / FWTM 12.0° / 25.0° Efficiency 82 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED CXA/B 15xx FWHM / FWTM 18.0° / 43.0° Efficiency 91 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 19.0° / 47.0° Efficiency 84 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED CXA/B 15xx FWHM / FWTM 26.0° / 66.0° Efficiency 77 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 441 Typ L1 LED CXA/B 15xx FWHM / FWTM 27.0° / 65.0° Efficiency 82 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13723_MIRELLA-RZL LED CXA/B 15xx FWHM / FWTM 21.0° / 56.0° Efficiency 87 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 20.0° / 60.0° Efficiency 84 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 441 Typ L1 LED CXA/B 15xx FWHM / FWTM 19.0° / 59.0° Efficiency 79 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 441 Typ L1 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 25.0° / 68.0° Efficiency 85 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C14115_PF-SOCKET-CXA15-18 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 23.0° / 67.0° Efficiency 89 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2101CR + 50-2100MR Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED MHD-E/G FWHM / FWTM 17.0° / 44.0° Efficiency 87 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED MHD-E/G FWHM / FWTM 15.0° / 32.0° Efficiency 87 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED MHD-E/G FWHM / FWTM 14.0° / 31.0° Efficiency 93 % Peak intensity 6.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MHD-E/G FWHM / FWTM 24.0° / 65.0° Efficiency 84 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED MK-R FWHM / FWTM 12.0° / 27.0° Efficiency 87 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MK-R FWHM / FWTM 15.0° / 37.0° Efficiency 82 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED MT-G FWHM / FWTM 18.0° / 34.0° Efficiency 86 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED MT-G FWHM / FWTM 19.0° / 46.0° Efficiency 85 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED MT-G FWHM / FWTM 17.0° / 34.0° Efficiency 90 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MT-G2 FWHM / FWTM 18.0° / 43.0° Efficiency 85 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED MT-G2 FWHM / FWTM 18.0° / 35.0° Efficiency 88 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MT-G2 FWHM / FWTM 16.0° / 33.0° Efficiency 84 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED XHP50 FWHM / FWTM 11.0° / 23.0° Efficiency 89 % Peak intensity 9.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED XHP50 FWHM / FWTM 22.0° / 60.0° Efficiency 81 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED XHP50 FWHM / FWTM 15.0° / 34.0° Efficiency 85 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED XHP50 FWHM / FWTM 12.0° / 25.0° Efficiency 84 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED XHP70 FWHM / FWTM 24.0° / 62.0° Efficiency 81 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED XHP70 FWHM / FWTM 17.0° / 40.0° Efficiency 84 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED XHP70 FWHM / FWTM 15.0° / 31.0° Efficiency 89 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED XHP70 FWHM / FWTM 16.0° / 32.0° Efficiency 83 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED XM-L RGBW (XMLCTW) FWHM / FWTM 22.0° / 55.0° Efficiency 80 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED XQ-E HI FWHM / FWTM 21.0° / 58.0° Efficiency 86 % Peak intensity 3.1 cd/lm LEDs/each optic 4 Light colour RGBW Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED LUXEON CoB 1202/1203 FWHM / FWTM 20.0° / 61.0° Efficiency 84 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 438 Typ L1 LED LUXEON CoB 1202/1203 FWHM / FWTM 20.0° / 61.0° Efficiency 78 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 438 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1202/1203 FWHM / FWTM 19.0° / 59.0° Efficiency 82 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13333_MIRELLA-CL IDEAL: 50-2100NC +50-2100MR LED LUXEON CoB 1202/1203 FWHM / FWTM 27.0° / 67.0° Efficiency 76 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 438 Typ L1 LED LUXEON CoB 1202/1203 FWHM / FWTM 22.0° / 61.0° Efficiency 83 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: C12479_MIRELLA-DL IDEAL: 50-2100NC +50-2100MR LED LUXEON CoB 1202/1203 FWHM / FWTM 19.0° / 50.0° Efficiency 87 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1202/1203 FWHM / FWTM 19.0° / 58.0° Efficiency 88 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2100NC +50-2100MR LED LUXEON CoB 1202s FWHM / FWTM 13.0° / 28.0° Efficiency 84 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED LUXEON CoB 1202s FWHM / FWTM 13.0° / 30.0° Efficiency 89 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED LUXEON CoB 1202s FWHM / FWTM 23.0° / 63.0° Efficiency 79 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 452 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1202s FWHM / FWTM 15.0° / 36.0° Efficiency 84 % Peak intensity 5.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED LUXEON Z FWHM / FWTM 21.0° / 54.0° Efficiency 78 % Peak intensity 3.2 cd/lm LEDs/each optic 4 Light colour RGBW Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED CxM-6 (12x13) FWHM / FWTM 14.0° / 32.0° Efficiency 86 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED CXM-7 (13x13) FWHM / FWTM 17.0° / 38.0° Efficiency 87 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED CxM-9 (13.5x13.5) FWHM / FWTM 30.0° / 70.0° Efficiency 81 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED CxM-9 (13.5x13.5) FWHM / FWTM 23.0° / 61.0° Efficiency 86 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED CxM-9 (13.5x13.5) FWHM / FWTM 21.0° / 58.0° Efficiency 85 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED COB L-Type (LES 11) FWHM / FWTM 25.0° / 68.0° Efficiency 86 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 24.0° / 68.0° Efficiency 81 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 438 Typ L1 LED COB L-Type (LES 11) FWHM / FWTM 24.0° / 65.0° Efficiency 78 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 438 Typ L1 LED COB L-Type (LES 11) FWHM / FWTM 24.0° / 65.0° Efficiency 81 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13333_MIRELLA-CL IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 11) FWHM / FWTM 26.0° / 67.0° Efficiency 80 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C12479_MIRELLA-DL IDEAL: 50-2100NC +50-2100MR Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 25.0° / 68.0° Efficiency 83 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 11) FWHM / FWTM 30.0° / 70.0° Efficiency 76 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 27.0° / 67.0° Efficiency 77 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 22.0° / 64.0° Efficiency 84 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2100NC +50-2100MR Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 9) FWHM / FWTM 18.0° / 56.0° Efficiency 83 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13333_MIRELLA-CL IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 9) FWHM / FWTM 19.0° / 57.0° Efficiency 85 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 18.0° / 58.0° Efficiency 80 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 19.0° / 52.0° Efficiency 88 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 9) FWHM / FWTM 24.0° / 66.0° Efficiency 78 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12479_MIRELLA-DL IDEAL: 50-2100NC +50-2100MR LED NSCxL036A FWHM / FWTM 16.0° / 38.0° Efficiency 86 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET LED Duris S10 FWHM / FWTM 13.0° / 31.0° Efficiency 87 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED Duris S10 FWHM / FWTM 22.0° / 61.0° Efficiency 82 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED Duris S10 FWHM / FWTM 18.0° / 54.0° Efficiency 80 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED Duris S10 FWHM / FWTM 13.0° / 30.0° Efficiency 81 % Peak intensity 6.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED OSTAR Stage (S2WP) FWHM / FWTM 21.0° / 58.0° Efficiency 83 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED Ostar-SMT RGB FWHM / FWTM 20.0° / 55.0° Efficiency 82 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED ZC4/6 FWHM / FWTM 19.0° / 44.0° Efficiency 83 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED ZC4/6 FWHM / FWTM 21.0° / 56.0° Efficiency 83 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED ZC4/6 FWHM / FWTM 18.0° / 42.0° Efficiency 88 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED Mini Zenigata (GW6BM) FWHM / FWTM 20.0° / 56.0° Efficiency 84 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (MEASURED): LED Mini Zenigata (GW6BM) FWHM / FWTM 17.0° / 41.0° Efficiency 91 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED XTM - 9mm LES FWHM / FWTM 20.0° / 61.0° Efficiency 82 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: C14636_XTM-PF-ADAPTER Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED XHP50.2 FWHM / FWTM 11.0° / 22.0° Efficiency 90 % Peak intensity 11.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CoB Compact FWHM / FWTM 23.0° / 63.0° Efficiency 79 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 452 Typ L1 LED LUXEON CoB Compact FWHM / FWTM 13.0° / 28.0° Efficiency 84 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED LUXEON CoB Compact FWHM / FWTM 13.0° / 30.0° Efficiency 89 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED LUXEON CoB Compact FWHM / FWTM 15.0° / 36.0° Efficiency 84 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED LUXEON K4 FWHM / FWTM 24.0° / 72.0° Efficiency 88 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED LUXEON K4 FWHM / FWTM 42.0° / 87.0° Efficiency 84 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED CxM-14 (19x19) FWHM / FWTM 33.0° / 72.0° Efficiency 69 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 433 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED CxM-14 (19x19) FWHM / FWTM 31.0° / 70.0° Efficiency 72 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 433 Typ L1 LED CxM-14 (19x19) FWHM / FWTM 29.0° / 72.0° Efficiency 76 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 LED CxM-9 (13.5x13.5) FWHM / FWTM 21.0° / 63.0° Efficiency 84 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 LED CxM-9 (13.5x13.5) FWHM / FWTM 27.0° / 67.0° Efficiency 77 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 35/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED CxM-9 (13.5x13.5) FWHM / FWTM 20.0° / 61.0° Efficiency 80 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED COB S-Type (LES 7) FWHM / FWTM 15.0° / 41.0° Efficiency 83 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 452 Typ L1 LED COB S-Type (LES 7) FWHM / FWTM 19.0° / 49.0° Efficiency 87 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 452 Typ L1 LED COB S-Type (LES 7) FWHM / FWTM 23.0° / 63.0° Efficiency 79 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 452 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 36/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED Duris S8 FWHM / FWTM 14.0° / 29.0° Efficiency 90 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED Duris S8 FWHM / FWTM 9.5° / 24.0° Efficiency 94 % Peak intensity 12.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED Soleriq S15 FWHM / FWTM 28.0° / 74.0° Efficiency 85 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 433 Typ L1 LED Soleriq S9 FWHM / FWTM 21.0° / 54.0° Efficiency 91 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 37/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED Soleriq S9 FWHM / FWTM 19.0° / 56.0° Efficiency 87 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 LED Soleriq S9 FWHM / FWTM 24.0° / 61.0° Efficiency 86 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED Soleriq S9 FWHM / FWTM 24.0° / 61.0° Efficiency 87 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED LC010C FWHM / FWTM 16.0° / 41.0° Efficiency 87 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 479 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 38/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED LC020C FWHM / FWTM 16.0° / 49.0° Efficiency 86 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 479 Typ L1 LED LC040C FWHM / FWTM 23.0° / 66.0° Efficiency 84 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 480 Typ L1 LED ZC4/6 FWHM / FWTM 20.0° / 61.0° Efficiency 80 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED ZC4/6 FWHM / FWTM 21.0° / 63.0° Efficiency 84 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 39/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF OPTICAL RESULTS (SIMULATED): LED ZC4/6 FWHM / FWTM 27.0° / 67.0° Efficiency 77 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 40/41 PRODUCT DATASHEET C13085_MIRELLA-50-S-PF GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 41/41
C13085_MIRELLA-50-S-PF 价格&库存
很抱歉,暂时无法提供与“C13085_MIRELLA-50-S-PF”相匹配的价格&库存,您可以联系我们找货
    • 1+20.625361+2.67810
    • 28+16.5351028+2.14700
    • 84+16.1869984+2.10180
    库存:70
