C14454_FLORENCE-1R-O
    LEDIL(芬兰)
C14454_FLORENCE-1R-O 数据手册
PRODUCT DATASHEET C14454_FLORENCE-1R-O FLORENCE-1R-O ~95° + 30° oval beam SPECIFICATION: Dimensions Height Fastening ROHS compliant 285.6 x 19.5 mm 7 mm glue, clips yes MATERIALS: Component Type Material Colour FLORENCE-1R-O Linear lens PMMA clear Finish ORDERING INFORMATION: Component C14454_FLORENCE-1R-O » Box size: 480 x 280 x 300 mm Qty in box 210 MOQ MPQ 45 15 Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.1 1/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O See also our general installation guide: www.ledil.com/installation_guide Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O OPTICAL RESULTS (MEASURED): LED L0-280024-xxx-C0800-L267 FWHM / FWTM 92.0 + 35.0° / 131.0 + 89.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3014 FWHM / FWTM 98.0 + 33.0° / 133.0 + 59.0° Efficiency 93 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3020 FWHM / FWTM 95.0 + 31.0° / 131.0 + 59.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 2D (Round LES) FWHM / FWTM 93.0 + 34.0° / 131.0 + 75.0° Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O OPTICAL RESULTS (MEASURED): LED LUXEON 3535L FWHM / FWTM 93.0 + 35.0° / 132.0 + 85.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED MP-2016 FWHM / FWTM 94.0 + 31.0° / 130.0 + 57.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757D FWHM / FWTM 93.0 + 34.0° / 137.0 + 85.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757G FWHM / FWTM 92.0 + 35.0° / 133.0 + 84.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O OPTICAL RESULTS (MEASURED): LED NFSW757H FWHM / FWTM 92.0 + 31.0° / 129.0 + 80.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14353_FLORENCE-1R-CLIP-A LED Duris S5 (2 chip) FWHM / FWTM 92.0 + 33.0° / 135.0 + 92.0° Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Line 1ft 2000lm 1R HV4 FWHM / FWTM 95.0 + 31.0° / 131.0 + 81.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14353_FLORENCE-1R-CLIP-A LED Fortimo LED Line 1ft HF 1R HV5 FWHM / FWTM 94.0 + 34.0° / 132.0 + 82.0° Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14353_FLORENCE-1R-CLIP-A Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O OPTICAL RESULTS (MEASURED): LED Fortimo LED Line 1ft MF 1R HV5 & LV5 FWHM / FWTM 93.0 + 34.0° / 131.0 + 80.0° Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14353_FLORENCE-1R-CLIP-A LED LM28xB Series FWHM / FWTM 94.0 + 34.0° / 132.0 + 80.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM301A FWHM / FWTM 93.0 + 32.0° / 132.0 + 73.0° Efficiency 92 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM302A FWHM / FWTM 92.0 + 34.0° / 132.0 + 80.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O OPTICAL RESULTS (MEASURED): LED LM561C FWHM / FWTM 94.0 + 32.0° / 131.0 + 75.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-S282N FWHM / FWTM 95.0 + 32.0° / 131.0 + 76.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL 3030 FWHM / FWTM 91.0 + 35.0° / 132.0 + 79.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 3030 FWHM / FWTM 92.0 + 30.0° / 129.0 + 67.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: C14353_FLORENCE-1R-CLIP-A Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O OPTICAL RESULTS (SIMULATED): LED LUXEON CZ FWHM / FWTM 95.0 + 33.0° / 136.0 + 56.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris E 2835 FWHM / FWTM 92.0 + 30.0° / 127.0 + 71.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris E5 FWHM / FWTM 92.0 + 32.0° / 125.0 + 78.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ C 2424 FWHM / FWTM 89.0 + 32.0° / 129.0 + 65.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O OPTICAL RESULTS (SIMULATED): LED OSLON SSL 150 FWHM / FWTM 98.0 + 32.0° / 140.0 + 70.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour Far Red Required components: LED SEOUL DC 3030C FWHM / FWTM 98.0 + 32.0° / 131.0 + 73.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET C14454_FLORENCE-1R-O GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 14/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
C14454_FLORENCE-1R-O 价格&库存
很抱歉,暂时无法提供与“C14454_FLORENCE-1R-O”相匹配的价格&库存,您可以联系我们找货
  • 1+33.80192
  • 15+30.44808
  • 45+27.01039
  • 90+24.45908
库存:44
  • 1+34.356181+4.44090
  • 15+30.9467915+4.00020
  • 45+27.4499745+3.54820
  • 90+24.8273790+3.20920
库存:44
