CA10932_FLARE-B-RE-TAPE
    LEDIL(芬兰)
CA10932_FLARE-B-RE-TAPE 数据手册
LEDIL F’FORM OPTICS Flare-B-RE lens for LUXEON REBEL series of LEDs Flare-B-RE - - Lens designed for Luxeon Rebel series of LEDs Lens material optical grade PMMA with high UV and temperature resistance (105°C/220°F). Allows use of high current and temperature conditions Best available optical efficiency Fastening to PCB & heat sink with 2 screws (C10946_Flare-B-RE) or very easy assembly with TAPE LED can be assembled parallel or perpendicular to the x,y axis (to turn the light distribution by 90°) Compact dimensions 23 x 25 mm. Square form enables easy build of a line without any gaps between lenses. Especially suitable for Beacon and other 360°° solutions and in linear solutions with high evenness requirements NAME ORDERING CODE Flare-B-RE Lens Flare-B-RE Lens + tape C10946_Flare-B-RE CA10932_Flare-B-RE-tape FWHM Angle ±5.5° x ±46° ±5.5° x ±46° © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS MEASUREMENTS Relative Intensity of C10946_Flare-B-RE 100% 75% 50% 25% 0% 90 80 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 -80 -90 © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS DRAWINGS © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28
CA10932_FLARE-B-RE-TAPE 价格&库存
很抱歉,暂时无法提供与“CA10932_FLARE-B-RE-TAPE”相匹配的价格&库存,您可以联系我们找货
