CA11264_HEIDI-D
CA11264_HEIDI-D
    LEDIL(芬兰)
CA11264_HEIDI-D 数据手册
PRODUCT DATASHEET CA11264_HEIDI-D HEIDI-D ~10° diffused spot beam SPECIFICATION: Dimensions Ø 21.6 mm Height 11.9 mm Fastening tape, pin ROHS compliant yes MATERIALS: Component Type Material Colour HEIDI-D Single lens PMMA clear HEIDI-TAPE Tape Acrylic foam black Finish Length 21.6 ORDERING INFORMATION: Component CA11264_HEIDI-D » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 3264 204 204 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 10.6 1/19 PRODUCT DATASHEET CA11264_HEIDI-D See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED XB-D FWHM / FWTM 10.0° / 22.0° Efficiency 90 % Peak intensity 12.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XB-H FWHM / FWTM 11.0° / 25.0° Efficiency 87 % Peak intensity 12.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XD16 FWHM / FWTM 10.0° / 22.0° Efficiency 93 % Peak intensity 14.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED XP-E FWHM / FWTM 9.0° / 18.0° Efficiency 93 % Peak intensity 22 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-E2 FWHM / FWTM 10.0° / 23.0° Efficiency 88 % Peak intensity 17.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G FWHM / FWTM 12.0° / 23.0° Efficiency 93 % Peak intensity 14.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED XP-G2 FWHM / FWTM 11.0° / 24.0° Efficiency 88 % Peak intensity 15 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HD FWHM / FWTM 10.0° / 24.0° Efficiency 94 % Peak intensity 14.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HI FWHM / FWTM 7.0° / 17.0° Efficiency 93 % Peak intensity 24.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED XT-E FWHM / FWTM 11.0° / 26.0° Efficiency 94 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON C FWHM / FWTM 9.0° / 21.0° Efficiency 89 % Peak intensity 17.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 7.0° / 16.0° Efficiency 94 % Peak intensity 29 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED LUXEON T FWHM / FWTM 12.0° / 25.0° Efficiency 89 % Peak intensity 11.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON TX FWHM / FWTM 12.0° / 25.0° Efficiency 88 % Peak intensity 13.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxx19A FWHM / FWTM 9.0° / 23.0° Efficiency 88 % Peak intensity 11.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED NCSxx19B FWHM / FWTM 11.0° / 25.0° Efficiency 85 % Peak intensity 14.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19A FWHM / FWTM 12.0° / 29.0° Efficiency 88 % Peak intensity 8.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 14.0° / 30.0° Efficiency 91 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 10.0° / 22.0° Efficiency 90 % Peak intensity 12.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 150 FWHM / FWTM 9.0° / 22.0° Efficiency 92 % Peak intensity 15 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 80 FWHM / FWTM 7.0° / 19.0° Efficiency 89 % Peak intensity 19.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED LH181A FWHM / FWTM 10.0° / 26.0° Efficiency 88 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH181B FWHM / FWTM 11.0° / 25.0° Efficiency 94 % Peak intensity 11.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351B FWHM / FWTM 14.0° / 29.0° Efficiency 88 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (MEASURED): LED LH351Z FWHM / FWTM 12.0° / 26.0° Efficiency 88 % Peak intensity 13.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5 FWHM / FWTM 8.0° / 20.0° Efficiency 87 % Peak intensity 22.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (SIMULATED): LED XP-E2 FWHM / FWTM 10.0° / 20.0° Efficiency 96 % Peak intensity 22.6 cd/lm LEDs/each optic 1 Light colour/type Green Required components: LED XP-L HI FWHM / FWTM 12.0° / 22.0° Efficiency 96 % Peak intensity 15.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 3030 HV FWHM / FWTM 11.0° / 23.0° Efficiency 94 % Peak intensity 16.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (SIMULATED): LED LUXEON HL2Z FWHM / FWTM 12.0° / 24.0° Efficiency 96 % Peak intensity 14.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rubix FWHM / FWTM 8.0° / 18.0° Efficiency 95 % Peak intensity 30.6 cd/lm LEDs/each optic 1 Light colour/type Red Required components: LED LUXEON SunPlus 20 Line (120 deg) FWHM / FWTM 8.0° / 18.0° Efficiency 96 % Peak intensity 26.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (SIMULATED): LED LUXEON SunPlus 20 Line (150 deg) FWHM / FWTM 8.0° / 18.0° Efficiency 91 % Peak intensity 24.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Z FWHM / FWTM 9.0° / 17.0° Efficiency 94 % Peak intensity 32.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Z ES FWHM / FWTM 7.7° / 16.0° Efficiency 94 % Peak intensity 33.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (SIMULATED): LED NCSxE17A FWHM / FWTM 22.0° / 42.0° Efficiency 93 % Peak intensity 4.1 cd/lm LEDs/each optic 4 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 12.0° / 22.0° Efficiency 94 % Peak intensity 15 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S5 (Single chip) FWHM / FWTM 12.0° / 24.0° Efficiency 96 % Peak intensity 14.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3030 FWHM / FWTM 9.4° / 20.0° Efficiency 97 % Peak intensity 23.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 13.0° / 26.0° Efficiency 94 % Peak intensity 13.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 150 FWHM / FWTM 10.0° / 20.0° Efficiency 96 % Peak intensity 23.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (SIMULATED): LED OSLON SSL 150 FWHM / FWTM 10.0° / 19.0° Efficiency 95 % Peak intensity 24.5 cd/lm LEDs/each optic 1 Light colour/type Red Required components: LED OSLON SSL 80 FWHM / FWTM 9.4° / 21.0° Efficiency 94 % Peak intensity 20.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SFH 4170S FWHM / FWTM 9.0° / 17.0° Efficiency 88 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/19 PRODUCT DATASHEET CA11264_HEIDI-D OPTICAL RESULTS (SIMULATED): LED Z5M1/Z5M2 FWHM / FWTM 10.0° / 22.0° Efficiency 90 % Peak intensity 17 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/19 PRODUCT DATASHEET CA11264_HEIDI-D GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/19
CA11264_HEIDI-D 价格&库存
很抱歉,暂时无法提供与“CA11264_HEIDI-D”相匹配的价格&库存,您可以联系我们找货
CA11264_HEIDI-D
  • 1+16.06250
  • 6+14.48140
  • 24+12.90031
库存:34
CA11264_HEIDI-D
  • 1+17.309221+2.23740
  • 6+15.560826+2.01140
  • 24+13.8998324+1.79670
库存:34
CA11264_HEIDI-D
  • 1+31.538121+4.07664
  • 10+23.1034610+2.98637
  • 204+17.01300204+2.19911
  • 612+15.67076612+2.02562
  • 1020+15.157421020+1.95926
  • 2040+14.554242040+1.88129
  • 5100+13.897365100+1.79639
库存:816
CA11264_HEIDI-D
  • 2+21.05158
  • 10+20.20805
  • 20+19.35933
库存:220
