CS16460_HB-IP-2X6-W-PC
    LEDIL(芬兰)
CS16460_HB-IP-2X6-W-PC 数据手册
4 3.2 3.2 (rib) Fasten middle screws first. Recommended torque with pan head screw: 0.57Nm (for 1.6mm thick PCB, no thermal pad) 3.5 Detail B Scale: 2:1 3.5 5.4 pcb typically 45mm ( 44.9 ) 54.2 2.65 54.2 hole Wiring: PCB is fully sealed between the lens with silicone seal and the heatsink. Wiring needs to be done trough the PCB and heat sink to maintain high IP rating. (silicone) pos pin 54.2 1.7 Detail A Scale: 2:1 3.2 1.65 50.8 DATE 22.10.2018 M3 screw size 6 Section view D-D Scale: 2:1 3 11.4 3 Led position B 5.4 61 25.4 4 25.4 PCB typically 146,6mm A A B C D E F G H ( 146.5 ) Silicone seal is tested to work in LEDiL test assemblies. Customer is recommended to test the sealing in the end product due many variables, such as heat sink surface and possible chemical traces 9.9 1.6 (1.6mm pcb) 2 2 D Ribs 71.4 D MECHANICAL DRAWING C C PC-Version from Section view C-C CS14130_HB-IP-2X6-W Scale: 1:1 PART TYPE MATERIAL COLOR / COATING C16459 HB-IP-2X6-W-PC PC CLEAR C14018 2X6-SEAL25 PRODUCT CS16460_HB-IP-2X6-W-PC 1 173 Notes PCB or heatsink level. LED location Ensure LED fitting from a product specific 3D model available from www.ledil.com For more details about installation please see LEDiL Installation Guide on www.ledil.com H G Plastic moulding general tolerances according to DIN 16901-130 and applies if not otherwise shown in the drawing. Silicone moulding general tolerances according to ISO 3302-1 Class M3 and applies if not otherwise shown in the drawing. SCALE 1:1 FIRST ANGLE PROJECTION: WEIGHT - This drawing is the property of LEDiL Oy. It may not be copied or otherwise distributed without prior written permission from LEDiL Oy. A3 B SHEET 1/1 A 1
CS16460_HB-IP-2X6-W-PC 价格&库存
很抱歉,暂时无法提供与“CS16460_HB-IP-2X6-W-PC”相匹配的价格&库存,您可以联系我们找货
