CS16515_SITARA-2X2-T2
    LEDIL(芬兰)
    Lens|square|4 Pos|50+50mm (D)|9,3mm(H)
CS16515_SITARA-2X2-T2 数据手册
PRODUCT DATASHEET CS16515_SITARA-2X2-T2 SITARA-2X2-T2 IESNA Type II (medium) beam, applicable for European P-class standard pedestrian lighting and M-class roads. SPECIFICATION: Dimensions Height Fastening 50.0 x 50.0 9.3 mm pin,screw Ingress protection classes ROHS compliant IP67 yes MATERIALS: Component Type Material Colour Finish Length SITARA-2X2-T2 Multi-lens PC clear 50.0 SITARA-2X2-SEAL Seal Silicone milky 45.6 ORDERING INFORMATION: Component CS16515_SITARA-2X2-T2 » Box size: 480 x 280 x 300 mm Qty in box 770 MOQ MPQ 154 154 Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.9 1/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 See also our general installation guide: www.ledil.com/installation_guide Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 OPTICAL RESULTS (MEASURED): LED LUXEON 5050 Round LES FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 OPTICAL RESULTS (SIMULATED): LED Bridgelux SMD 5050 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CSP 2323 (BXCP) FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED J Series 5050 Round LES FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 OPTICAL RESULTS (SIMULATED): LED MHB-A/B FWHM / FWTM Asymmetric Efficiency 74 % LEDs/each optic 1 Light colour/type White Required components: LED XP-G3 FWHM / FWTM Asymmetric Efficiency 79 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L2 FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 OPTICAL RESULTS (SIMULATED): LED XT-E FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5050 Square LES FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2X FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 OPTICAL RESULTS (SIMULATED): LED NV4WB35AM FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3737 (3W version) FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351B FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 OPTICAL RESULTS (SIMULATED): LED LH351C FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351D FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH508A Plus FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET CS16515_SITARA-2X2-T2 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 11/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
CS16515_SITARA-2X2-T2 价格&库存
很抱歉,暂时无法提供与“CS16515_SITARA-2X2-T2”相匹配的价格&库存,您可以联系我们找货
  • 154+20.40568154+2.64170
