F12237 OSLO-CLUSTER-W-OSL 数据手册
PRODUCT DATASHEET
Oslo series
Ordering number F12237
Description
F12237-Oslo-Cluster-W-OSL
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Oslo
Lens
Oslon SSL 80
Transparent
26 mm
6.7 mm
Round
PMMA
Pin, glue
Ready
FWHM
Efficiency
cd/lm
Gerber File
64 degrees
Available
Cluster
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
September 13th 2011 11:19 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Oslo series
GENERAL INFORMATION
- Product series especially designed & optimized for Oslon SSL 80 series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue
options.
http://www.ledil.com/datasheets/DataSheet_GLUES.pdf
NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end
product. For example, mechanical stress, vibration and holes on the surface of the circuit boar
weaken the strength of the glue.
NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If
cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED
manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other
electronics components on the PCB.
Further note that optical components shall not be cleaned with any chemicals - only micro fiber
cloth may be used to remove fingerprints or other traces from handling.
September 13th 2011 11:19 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2
Ledil Oy
Salorankatu 10
24240 SALO
Finland
A
B
C
D
7 x led
.4
18
13
.6
4
4
7.
7)
Isometric view
Scale: 2:1
2
3
26
3
1.2
6.7
2
Material: PMMA
Part no.s:
F11355_Oslo-Cluster-W-OSL
F11355_Oslo-Cluster-W-XP
F11355_Oslo-Cluster-W-RE
F11355_Oslo-Cluster-W-N119
1
This drawing is our property.
It can't be reproduced
or communicated without
our written agreement.
DRAWN BY
DATE
CHECKED BY
DATE
Led
Teh
FIN
Fin
DRAWING TITLE
Datasheet
pv
24.05.2010
tk
24.05.2010
DESIGNED BY
hh
DATE
24.05.2010
D
SIZE
Oslo-Cluster-W Series 1
DRAWING NUMBER
A4
SCALE
2:1 WEIGHT(g)
REV
F11355
1
SHEET
A
1/1
F12237 OSLO-CLUSTER-W-OSL 价格&库存
很抱歉,暂时无法提供与“F12237 OSLO-CLUSTER-W-OSL”相匹配的价格&库存,您可以联系我们找货
