F13660_ANGELINA-M-B
F13660_ANGELINA-M-B
    LEDIL(芬兰)
    REFLECTOR ROUND 1 POS 82MM D 31M
F13660_ANGELINA-M-B 数据手册
PRODUCT DATASHEET ANGELINA series last update 19/8/2014 DETAILS Product Number F13660_ANGELINA-M-B Family ANGELINA Type Reflector Color metal Diameter 82 mm Height 31 mm Style round Optic Material PC Holder Material Fastening Status ready ROHS Comliant Yes Date Updated 13/06/2014 OPTICAL PROPERTIES LED Viewing Angle LUXEON K12 (simulated) 29 Light Beam Efficiency cd/lm connector - (simulated) 0.000 Solderless Connector 47.319.2070 BJB LUXEON K16 (simulated) 31 - (simulated) 0.000 Solderless Connector 47.319.2070 BJB CLL04x/CLU044 (simulated) 37 (simulated) 95 % (simulated) 1.600 Solderless Connector 47.319.2030 BJB COB 10W/13W/17W/24W (simulated) 36 - (simulated) 0.000 Solderless Connector 47.319.2080 BJB CLL03x/CLU034 37 degrees 92 % 1.400 Solderless Connector Soleriq S13 37 degrees 94 % 1.270 8502/G2 A.A.G. STUCCHI BXRA ES Rectangle 38 degrees 92 % 1.320 Solderless Connector 47.319.2020 BJB 47.319.2040 BJB CXM-14 40 degrees 94 % 1.300 Solderless Connector 47.319.2020 BJB Soleriq S19 41 degrees 93 % 1.200 8503/G2 A.A.G. STUCCHI Soleriq S19 41 degrees 94 % 1.170 Solderless Connector Soleriq E30 42 degrees 90 % 1.190 CXM-22 48 degrees 92 % 1.000 47.319.2170 BJB Solderless Connector 47.319.2090 BJB Solderless Connector 47.319.2030 BJB September 17th 2014 16:11 Copyright Ledil Oy - Subject to change without prior notice - Page 1/1 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A 0.75 0.8 B C D 31 4 4 Detail A Scale: 2:1 R 2.2 A 8 9 1. . 21 33 3 R2 .1 2 5 R 21.8 39 3 3 Detail B Scale: 2:1 B 2 2 INDEX PART NO DESCRIPTION MATERIAL COLOUR 1 Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: Up to 30mm class F, otherwise class M. According to DIN ISO 2768-2 Form and position: class K 1 THIRD ANGLE PROJECTION: This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy." PC metal Ledil Oy Salorankatu 10 FIN 24240 SALO Finland DRAWING TITLE ANGELINA-B series Reflector SIZE 1 PART NUMBER A4 SCALE D ANGELINA-B 1:1 WEIGHT - SHEET A 1/1 NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. GENERAL INFORMATION - Product series especially designed & optimized for series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (short term 100 degrees of Celcius / 212 degrees of Fahrenheit). Note! Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range.
F13660_ANGELINA-M-B 价格&库存
很抱歉,暂时无法提供与“F13660_ANGELINA-M-B”相匹配的价格&库存,您可以联系我们找货
