FN17294_VIOLET-12X1-S 数据手册
PRODUCT
DATASHEET
VIOLET-12X1-S
~20° wide beam when used with one UV LED
TECHNICAL SPECIFICATIONS:
Dimensions
Height
Fastening
294.8 x 41.6 mm
8.8 mm
screw
Ingress protection classes
ROHS compliant
IP67
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
VIOLET-12X1-S
Multi-lens
Silicone
clear
VIOLET-12X1-FRAME
Accessory
Stainless steel
metal
Finish
ORDERING INFORMATION:
Component
» Box size: 398 x 298 x 150 mm
Qty in box
Multi-lens
78
MOQ
MPQ
26
26
Box weight (kg)
7.7
Last update: 05/05/2020
Subject to change without prior notice
Published: 04/05/2020
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/11
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/11
PRODUCT
DATASHEET
PHOTOMETRIC DATA (MEASURED):
LED
LIGHT ENGINE VIOLET UVC 281x19.2mm (KL265-50V-SM-WD)
FWHM
15.0°
Efficiency
55 %
LEDs/each optic 1
Light colour
UV-C
Required components:
The UVC LED result tolerance is ±10 %
LED
KL265-50V-SM-WD
FWHM
16.0°
Efficiency
55 %
LEDs/each optic 1
Light colour
UV-C
LED
LTPL-G35UV275GC-E
FWHM
15.0°
Efficiency
63 %
LEDs/each optic 1
Light colour
UV-C
LED
LTPL-G35UV275GR-E
FWHM
21.0°
Efficiency
63 %
LEDs/each optic 1
Light colour
UV-C
3/11
PRODUCT
DATASHEET
LED
LTPL-G35UVC275GH
FWHM
26.0°
Efficiency
61 %
LEDs/each optic 1
Light colour
UV-C
LED
LTPL-G35UVC275GZ
FWHM
28.0°
Efficiency
62 %
LEDs/each optic 1
Light colour
UV-C
LED
XBT-3535-UV
FWHM
32.0°
Efficiency
64 %
LEDs/each optic 1
Light colour
UV-C
LED
XST-3535-UV
FWHM
23.0°
Efficiency
62 %
LEDs/each optic 1
Light colour
UV-C
4/11
PRODUCT
DATASHEET
LED
NCSU334A
FWHM
23.0°
Efficiency
64 %
LEDs/each optic 1
Light colour
UV-C
LED
NCSU334B
FWHM
26.0°
Efficiency
61 %
LEDs/each optic 1
Light colour
UV-C
LED
CUD7GF1A
FWHM
13.0°
Efficiency
57 %
LEDs/each optic 1
Light colour
UV-C
LED
CUD7GF1B
FWHM
19.0°
Efficiency
56 %
LEDs/each optic 1
Light colour
UV-C
5/11
PRODUCT
DATASHEET
LED
CUD7QF1A
FWHM
14.0°
Efficiency
54 %
LEDs/each optic 1
Light colour
UV-C
LED
XMD-FBC-LLCA
FWHM
17.0°
Efficiency
60 %
LEDs/each optic 1
Light colour
UV-C
LED
XMD-FBC-LLOA
FWHM
32.0°
Efficiency
58 %
LEDs/each optic 2
Light colour
UV-C
LED
XMD-FBC-LLVA
FWHM
45.0°
Efficiency
58 %
LEDs/each optic 4
Light colour
UV-C
6/11
PRODUCT
DATASHEET
PHOTOMETRIC DATA (SIMULATED):
LED
XT-E
FWHM
30.0°
Efficiency
86 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
LTPL-G35UV275GC-E
FWHM
46.0°
Efficiency
72 %
LEDs/each optic
1
Light colour
UV-C
LED
LTPL-G35UV275GR-E
FWHM
40.0°
Efficiency
72 %
LEDs/each optic
1
Light colour
UV-C
LED
LTPL-G35UVC275GM
FWHM
22.0°
Efficiency
66 %
LEDs/each optic
1
Light colour
UV-C
7/11
PRODUCT
DATASHEET
LED
XBT-3535-UV
FWHM
29.0°
Efficiency
72 %
LEDs/each optic
1
Light colour
UV-C
LED
NCSU334A
FWHM
40.0°
Efficiency
72 %
LEDs/each optic
1
Light colour
UV-C
LED
NCSU334B
FWHM
39.0°
Efficiency
75 %
LEDs/each optic
1
Light colour
UV-C
LED
LM301B
FWHM
38.0°
Efficiency
88 %
Peak intensity
1.8 cd/lm
LEDs/each optic
1
Light colour
White
8/11
PRODUCT
DATASHEET
LED
CUD7GF1B
FWHM
52.0°
Efficiency
74 %
LEDs/each optic
1
Light colour
UV-C
LED
CUD8AF4D
FWHM
38.0°
Efficiency
72 %
LEDs/each optic
1
Light colour
UV-C
LED
WICOP DY9560-27
FWHM
43.0°
Efficiency
66 %
LEDs/each optic
4
Light colour
UV-C
LED
WICOP DY9560-27
FWHM
22.0°
Efficiency
72 %
LEDs/each optic
1
Light colour
UV-C
9/11
PRODUCT
DATASHEET
LED
WICOP DY9560-27
FWHM
28.0°
Efficiency
70 %
LEDs/each optic
2
Light colour
UV-C
LED
ZEU110BEAE-265
FWHM
32.0°
Efficiency
70 %
Peak intensity
2 cd/lm
LEDs/each optic
1
Light colour
UV-C
10/11
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
11/11
FN17294_VIOLET-12X1-S 价格&库存
很抱歉,暂时无法提供与“FN17294_VIOLET-12X1-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+577.61193
- 5+505.41341
- 10+427.46036
