FP13028_LISA2-M-PIN
FP13028_LISA2-M-PIN
    LEDIL(芬兰)
    ASSEMBLY ROUND 1 POS 9.9MM D 6.8
FP13028_LISA2-M-PIN 数据手册
PRODUCT DATASHEET FP13028_LISA2-M-PIN LISA2-M-PIN ~20° medium beam. 6.8 mm high variant with location pin installation. SPECIFICATION: Dimensions Height Fastening ROHS compliant Ø 9.9 mm 6.8 mm glue, pin yes MATERIALS: Component Type Material Colour Finish Length LISA2-M Single lens PMMA clear 9.9 LISA2-HLD-PIN Holder PC black 9.9 ORDERING INFORMATION: Component FP13028_LISA2-M-PIN » Box size: Qty in box Single lens 2000 MOQ MPQ 100 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 1.4 1/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (MEASURED): LED XT-E FWHM / FWTM 26.0° / 49.0° Efficiency 89 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON T FWHM / FWTM 28.0° / 54.0° Efficiency 87 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON TX FWHM / FWTM 26.0° / 51.0° Efficiency 88 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (MEASURED): LED NVSxx19B/NVSxx19C FWHM / FWTM 30.0° / 58.0° Efficiency 86 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square EC FWHM / FWTM 26.0° / 49.0° Efficiency 84 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH181B FWHM / FWTM 20.0° / 53.0° Efficiency 78 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (MEASURED): LED LH351Z FWHM / FWTM 26.0° / 50.0° Efficiency 87 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (SIMULATED): LED CSP 2323 (BXCP) FWHM / FWTM 19.0° / 48.0° Efficiency 82 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON IR Compact FWHM / FWTM 15.0° / 31.0° Efficiency 85 % LEDs/each optic 1 Light colour/type IR Required components: LED LUXEON Rebel ES FWHM / FWTM 24.0° / 49.0° Efficiency 90 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (SIMULATED): LED SST-20 FWHM / FWTM 20.0° / 42.0° Efficiency 89 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxx19B FWHM / FWTM 19.0° / 42.0° Efficiency 85 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxE21A FWHM / FWTM 18.0° / 44.0° Efficiency 85 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 21.0° / 44.0° Efficiency 91 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 150 FWHM / FWTM 16.0° / 33.0° Efficiency 91 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SFH 4715AS FWHM / FWTM 26.0° / 45.0° Efficiency 89 % LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (SIMULATED): LED SFH 4716AS FWHM / FWTM 16.0° / 36.0° Efficiency 89 % LEDs/each optic 1 Light colour/type White Required components: LED SFH 4770S FWHM / FWTM 12.0° / 30.0° Efficiency 90 % LEDs/each optic 1 Light colour/type IR Required components: LED Z5M1/Z5M2 FWHM / FWTM 23.0° / 45.0° Efficiency 91 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN OPTICAL RESULTS (SIMULATED): LED Z8Y22P FWHM / FWTM 25.0° / 56.0° Efficiency 84 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/11 PRODUCT DATASHEET FP13028_LISA2-M-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/11
FP13028_LISA2-M-PIN 价格&库存
很抱歉,暂时无法提供与“FP13028_LISA2-M-PIN”相匹配的价格&库存,您可以联系我们找货
FP13028_LISA2-M-PIN
  • 100+16.04356
  • 200+15.64263
  • 400+15.40207
库存:155
FP13028_LISA2-M-PIN
  • 4+26.82917
  • 28+26.23558
  • 52+25.67011
库存:155
