C10909_EVA-XM-WW
C10909_EVA-XM-WW
    LEDIL(芬兰)
C10909_EVA-XM-WW 数据手册
PRODUCT DATASHEET Eva-single series Ordering number C12041 Description C12041_Eva-S-XM Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Lens XM-L Transparent 35 mm 16.4 mm Round PMMA Ready FWHM Efficiency cd/lm Gerber File 13 degrees 94 % Available Outer flange can be secured in fixture for hardware-free attachm Ordering number C10684 Description C10684_Eva-XM-D Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Lens XM-L Transparent 35 mm 16.4 mm Round PMMA Ready FWHM Efficiency cd/lm Gerber File 16 degrees 91 % Available Outer flange can be secured in fixture for hardware-free attachm Ordering number C10685 Description C10685_Eva-XM-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Lens XM-L Transparent 35 mm 16.4 mm Round PMMA Ready FWHM Efficiency cd/lm Gerber File 24 degrees 88 % Available Outer flange can be secured in fixture for hardware-free attachm Ordering number C10686 Description C10686_Eva-XM-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Lens XM-L Transparent 35 mm 16.4 mm Round PMMA Ready FWHM Efficiency cd/lm Gerber File 40 degrees 79 % Available Outer flange can be secured in fixture for hardware-free attachm January 3rd 2012 12:11 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Eva-single series Ordering number C10909 Description C10909_Eva-XM-WW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Lens XM-L Transparent 35 mm 16.4 mm Round PMMA Ready FWHM Efficiency cd/lm Gerber File 64 degrees 77 % Available Outer flange can be secured in fixture for hardware-free attachm NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. January 3rd 2012 12:11 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Eva-single series GENERAL INFORMATION - Product series especially designed & optimized for XM-L series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf January 3rd 2012 12:11 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001
C10909_EVA-XM-WW 价格&库存
很抱歉,暂时无法提供与“C10909_EVA-XM-WW”相匹配的价格&库存,您可以联系我们找货
