C11394_TYRA-S
C11394_TYRA-S
    LEDIL(芬兰)
    REFLECTOR 1P 40MM RND OD 23.1MM
C11394_TYRA-S 数据手册
PRODUCT DATASHEET Tyra series last update 30/9/2014 Product number C11394_TYRA-S Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tyra Reflector MP-L Metal 40 mm 23.1 mm Round PC Socket On production Product number C11395_TYRA-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tyra Reflector MP-L Metal 40 mm 23.1 mm Round PC Socket On production Product number C11396_TYRA-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tyra Reflector MP-L Metal 40 mm 23.1 mm Round PC Socket On production FWHM Efficiency cd/lm Gerber File 20 degrees (simulated) 0.000 Available Used with Tyco holder FWHM Efficiency cd/lm Gerber File 32 degrees (simulated) 0.000 Available Used with Tyco holder FWHM Efficiency cd/lm Gerber File 52 degrees (simulated) 0.000 Available Used with Tyco holder NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. May 14th 2015 12:22 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Tyra series last update 30/9/2014 GENERAL INFORMATION - Product series especially designed & optimized for MP-L series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (short term 100 degrees of Celcius / 212 degrees of Fahrenheit). May 14th 2015 12:22 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative Intensity of C11396_Tyra-W 100 % 75 % 50 % 25 % 0% 40 30 20 10 0 -10 -20 -30 -40 A B C D 2 4 11 4 1. 20.53 Isometric view Scale: 1:1 3 2.25 3 23.07 Bottom view Scale: 1:1 Front view Scale: 1:1 4 0 0. 1 2 2 11 Top view Scale: 1:1 Material: PC Metal coating with laquering This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 DRAWN BY ah DATE Ledil Oy Tehdaskatu 13 FIN-24100 SALO Finland DRAWING TITLE Datasheet Tyra series 25.7.2011 CHECKED BY DATE sn 25.7.2011 DESIGNED BY DATE ol 07.07.2010 D .2 SIZE DRAWING NUMBER REV 3 A4 SCALE 2:1 WEIGHT(g) SHEET A 1/1 1
C11394_TYRA-S 价格&库存
很抱歉,暂时无法提供与“C11394_TYRA-S”相匹配的价格&库存,您可以联系我们找货
