C15960_STRADELLA-8-HV-T4B
    LEDIL(芬兰)
C15960_STRADELLA-8-HV-T4B 数据手册
PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B STRADELLA-8-HV-T4B Wide IESNA Type IV forward-throw beam for wide area lighting like car parks. Variant with improved creepage distance for high voltage circuit designs. SPECIFICATION: Dimensions Height Fastening ROHS compliant 49.5 x 49.5 5.8 mm pin, screw yes MATERIALS: Component Type Material Colour STRADELLA-8-HV-T4B Multi-lens PMMA clear Finish Length 49.5 ORDERING INFORMATION: Component C15960_STRADELLA-8-HV-T4B » Box size: 480 x 280 x 300 mm Qty in box 800 MOQ MPQ 160 160 Box weight (kg) 7.0 Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B See also our general installation guide: www.ledil.com/installation_guide Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (MEASURED): LED J Series 3030 FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XD16 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (MEASURED): LED LUXEON 3030 2D (Round LES) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219D FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (MEASURED): LED NVSW319B FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ S 3030 (QSLR31) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 4x8up PR G5 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (MEASURED): LED SEOUL DC 3030C FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M4 FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED J Series 5050B 6V K Class FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G3 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED XP-G3 FWHM / FWTM Asymmetric Efficiency 75 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED XP-G4 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G4 FWHM / FWTM Asymmetric Efficiency 79 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 Square LES FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON C FWHM / FWTM Asymmetric Efficiency 74 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LUXEON CZ FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED LUXEON TX FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON TX FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED NF2x757G FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED NVSW219F FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219F FWHM / FWTM Asymmetric Efficiency 75 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED NVSW519A FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED NVSW519A FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 2424 FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED OSCONIQ C 2424 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 3030 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 3030 FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3030 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Pure 1414 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Pure 1414 FWHM / FWTM Asymmetric Efficiency 79 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED Fortimo FastFlex LED 4x8up PR G5 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LH181A FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH181B FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED LH351B FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LH351B FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351C FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED LH351C FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED SEOUL 3030 FWHM / FWTM Asymmetric Efficiency 98 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SEOUL 3030 FWHM / FWTM Asymmetric Efficiency 98 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED SEOUL DC 5050 6V FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SEOUL DC 5050 6V FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B OPTICAL RESULTS (SIMULATED): LED Z5M4 FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/21 PRODUCT DATASHEET C15960_STRADELLA-8-HV-T4B GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/04/2024 Subject to change without prior notice Published: 15/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/21
C15960_STRADELLA-8-HV-T4B 价格&库存
很抱歉,暂时无法提供与“C15960_STRADELLA-8-HV-T4B”相匹配的价格&库存,您可以联系我们找货
