C15984_STRADELLA-8-HV-HB-M 数据手册
PRODUCT
DATASHEET
STRADELLA-8-HV-HB-M
~65° medium beam for industrial applications.
Variant with improved creepage distance for
high voltage circuit designs.
SPECIFICATION:
Dimensions
Height
Fastening
ROHS compliant
49.5 x 49.5 mm
5.7 mm
pin, screw
yes
MATERIALS:
Component
Type
Material
Colour
STRADELLA-8-HV-HB-M
Multi-lens
PMMA
clear
Finish
ORDERING INFORMATION:
Component
» Box size: 480 x 280 x 300 mm
Qty in box
800
MOQ
MPQ
160
160
Box weight (kg)
4.4
Last update: 27/11/2023
Subject to change without prior notice
Published: 25/10/2019
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/11
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/11
PRODUCT
DATASHEET
OPTICAL RESULTS (MEASURED):
LED
J Series 3030
FWHM / FWTM
62.0° / 123.0°
Efficiency
97 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XD16
FWHM / FWTM
64.0° / 132.0°
Efficiency
92 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XT-E
FWHM / FWTM
62.0° / 137.0°
Efficiency
94 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
SST-10-B130
FWHM / FWTM
59.0° / 126.0°
Efficiency
94 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
Deep Red
3/11
PRODUCT
DATASHEET
LED
NF2W585AR
FWHM / FWTM
73.0° / 132.0°
Efficiency
94 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ S 3030 (QSLR31)
FWHM / FWTM
63.0° / 121.0°
Efficiency
94 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Fortimo FastFlex LED 4x8up PR G5
FWHM / FWTM
60.0° / 122.0°
Efficiency
94 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH151B
FWHM / FWTM
49.0° / 118.0°
Efficiency
93 %
Peak intensity
0.8 cd/lm
LEDs/each optic
1
Light colour
White
4/11
PRODUCT
DATASHEET
LED
SEOUL DC 3030C
FWHM / FWTM
60.0° / 121.0°
Efficiency
94 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M3
FWHM / FWTM
71.0° / 132.0°
Efficiency
94 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M4
FWHM / FWTM
71.0° / 118.0°
Efficiency
98 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y19
FWHM / FWTM
80.0° / 130.0°
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
5/11
PRODUCT
DATASHEET
LED
Z8Y22
FWHM / FWTM
81.0° / 131.0°
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
6/11
PRODUCT
DATASHEET
OPTICAL RESULTS (SIMULATED):
LED
XP-G2 HE
FWHM / FWTM
70.0° / 128.0°
Efficiency
95 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G3
FWHM / FWTM
72.0° / 132.0°
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G3
FWHM / FWTM
74.0° / 132.0°
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON 3535L HE
FWHM / FWTM
52.0° / 122.0°
Efficiency
93 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
7/11
PRODUCT
DATASHEET
LED
LUXEON HR30
FWHM / FWTM
54.0° / 121.0°
Efficiency
93 %
Peak intensity
0.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON TX
FWHM / FWTM
61.0° / 128.0°
Efficiency
94 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSW519A
FWHM / FWTM
78.0° / 124.0°
Efficiency
92 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
65.0° / 124.0°
Efficiency
91 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
8/11
PRODUCT
DATASHEET
LED
OSCONIQ C 2424
FWHM / FWTM
57.0° / 119.0°
Efficiency
96 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ C 3030
FWHM / FWTM
60.0° / 122.0°
Efficiency
96 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ C 3030
FWHM / FWTM
60.0° / 120.0°
Efficiency
87 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
Protective plate, glass
LED
OSCONIQ P 3030
FWHM / FWTM
49.0° / 119.0°
Efficiency
97 %
Peak intensity
0.9 cd/lm
LEDs/each optic
1
Light colour
White
9/11
PRODUCT
DATASHEET
LED
LH181A
FWHM / FWTM
67.0° / 135.0°
Efficiency
94 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH181B
FWHM / FWTM
59.0° / 122.0°
Efficiency
94 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351D
FWHM / FWTM
79.0° / 124.0°
Efficiency
94 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y22T
FWHM / FWTM
64.0° / 125.0°
Efficiency
94 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
10/11
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
11/11
C15984_STRADELLA-8-HV-HB-M 价格&库存
很抱歉,暂时无法提供与“C15984_STRADELLA-8-HV-HB-M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 160+11.94958160+1.49850
- 320+11.86107320+1.48740
- 480+11.77255480+1.47630
- 640+11.71702640+1.46934
- 800+11.59552800+1.45410
- 国内价格 香港价格
- 1+32.960921+4.13337
- 10+24.2492210+3.04090
- 160+18.32005160+2.29737
- 640+16.52771640+2.07261
- 1120+15.956721120+2.00101
- 2080+15.408742080+1.93229
- 5120+14.744555120+1.84900
