CA11171_TINA2-RS
CA11171_TINA2-RS
    LEDIL(芬兰)
    Lens with Holder Clear 14° Spot Nichia 183/083 Adhesive
CA11171_TINA2-RS 数据手册
PRODUCT DATASHEET CA11171_TINA2-RS TINA2-RS ~14° spot beam optimized for Nichia NS6x83. Assembly with holder and installation tape. SPECIFICATION: Dimensions Height Ø 16.1 mm 11 mm Fastening ROHS compliant tape yes MATERIALS: Component Type Material Colour Finish Length TINA2-RS Single lens PMMA clear 16.1 TINA2-HLD-N83-BLK Holder PC black 16.1 TINA-TAPE3 Tape Acrylic foam black 16.0 ORDERING INFORMATION: Component CA11171_TINA2-RS » Box size: 451 x 241 x 298 mm Qty in box MOQ MPQ 4140 230 230 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.4 1/13 PRODUCT DATASHEET CA11171_TINA2-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (MEASURED): LED MX-6 FWHM / FWTM 18.0° / 40.0° Efficiency 89 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V FWHM / FWTM 21.0° / 41.0° Efficiency 82 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NS3x83 FWHM / FWTM 15.0° Efficiency 93 % LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (MEASURED): LED NS6x83 FWHM / FWTM 19.0° / 42.0° Efficiency 93 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH508A FWHM / FWTM 26.0° / 53.0° Efficiency 76 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED XP-E2 FWHM / FWTM 12.0° / 22.0° Efficiency 91 % Peak intensity 18.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM 14.0° / 27.0° Efficiency 91 % Peak intensity 12.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G3 FWHM / FWTM 16.0° / 34.0° Efficiency 87 % Peak intensity 7.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED XP-L HI FWHM / FWTM 14.0° / 28.0° Efficiency 92 % Peak intensity 10.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 14.0° / 26.0° Efficiency 85 % Peak intensity 11.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 12.0° / 22.0° Efficiency 92 % Peak intensity 17.7 cd/lm LEDs/each optic 1 Light colour/type Red Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED LUXEON HL2X FWHM / FWTM 16.0° / 32.0° Efficiency 91 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SFT-12R-WES FWHM / FWTM 10.0° / 20.0° Efficiency 92 % Peak intensity 23 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SST-20 FWHM / FWTM 12.0° / 24.0° Efficiency 88 % Peak intensity 14.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED NV4WB35AM FWHM / FWTM 22.0° / 40.0° Efficiency 89 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NV4WB35AM FWHM / FWTM 22.0° / 40.0° Efficiency 89 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219F FWHM / FWTM 16.0° / 32.0° Efficiency 91 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED NVSW519A FWHM / FWTM 20.0° / 39.0° Efficiency 86 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 16.0° / 31.0° Efficiency 86 % Peak intensity 8.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 14.0° / 30.0° Efficiency 90 % Peak intensity 9.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED SFH 4715AS FWHM / FWTM 10.0° / 20.0° Efficiency 89 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4716AS FWHM / FWTM 12.0° / 22.0° Efficiency 88 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4717AS FWHM / FWTM 12.0° / 25.0° Efficiency 85 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED SFH 4725AS FWHM / FWTM 10.0° / 20.0° Efficiency 89 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4725S FWHM / FWTM 12.0° / 20.0° Efficiency 89 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4727AS FWHM / FWTM 13.0° / 25.0° Efficiency 85 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/13 PRODUCT DATASHEET CA11171_TINA2-RS OPTICAL RESULTS (SIMULATED): LED LH351B FWHM / FWTM 16.0° / 32.0° Efficiency 90 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351C FWHM / FWTM 18.0° / 33.0° Efficiency 92 % Peak intensity 7.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/13 PRODUCT DATASHEET CA11171_TINA2-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/13
CA11171_TINA2-RS 价格&库存
很抱歉,暂时无法提供与“CA11171_TINA2-RS”相匹配的价格&库存,您可以联系我们找货
CA11171_TINA2-RS
    • 2+25.40456
    • 58+24.84742
    • 116+24.31111
    库存:30
    CA11171_TINA2-RS
      • 230+12.37978230+1.55400
      • 460+12.20293460+1.53180
      CA11171_TINA2-RS
      • 230+10.25753230+1.28760
      • 460+10.16911460+1.27650
      • 920+10.08068920+1.26540
      • 1150+10.033131150+1.25944
      • 3450+9.903833450+1.24320
      CA11171_TINA2-RS
        • 230+9.01956230+1.13220
        • 460+8.93113460+1.12110
        • 690+8.75427690+1.09890
        • 920+8.71006920+1.09335
        • 1150+8.533211150+1.07115
