CA14505_G2-LXP2-RS2-P
    LEDIL(芬兰)
    LENSASSY1POS21.8MMRNDBLACK
CA14505_G2-LXP2-RS2-P 数据手册
PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P G2-LXP2-RS2-P ~8.5° spot beam with light, black holder. Assembly with location pins and installation tape. SPECIFICATION: Dimensions Ø 21.8 Height 14.7 mm Fastening pin, tape ROHS compliant yes MATERIALS: Component Type Material Colour LXP2-RS2 Single lens PMMA LXP2-LT-HLD Holder PC black HEIDI-TAPE Tape Acrylic foam black Finish Length 20.0 21.6 ORDERING INFORMATION: Component CA14505_G2-LXP2-RS2-P » Box size: 480 x 280 x 300 mm Qty in box MOQ MPQ 1680 336 112 Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.1 1/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P See also our general installation guide: www.ledil.com/installation_guide Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (MEASURED): LED XP-E FWHM / FWTM 7.0° / 15.0° Efficiency 88 % Peak intensity 34.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HD FWHM / FWTM 14.0° / 29.0° Efficiency 90 % Peak intensity 9.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HD FWHM / FWTM 5.0° / 13.0° Efficiency 89 % Peak intensity 42 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (MEASURED): LED XQ-E HI FWHM / FWTM 5.0° / 13.0° Efficiency 88 % Peak intensity 40.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rebel ES FWHM / FWTM 9.0° / 20.0° Efficiency 90 % Peak intensity 17.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V FWHM / FWTM 14.0° / 32.0° Efficiency 89 % Peak intensity 8.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (MEASURED): LED LUXEON V2 FWHM / FWTM 9.0° / 22.0° Efficiency 90 % Peak intensity 15.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxx19A FWHM / FWTM 6.8° / 18.0° Efficiency 89 % Peak intensity 21.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219D FWHM / FWTM 12.0° / 22.0° Efficiency 93 % Peak intensity 16 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (MEASURED): LED NVSW319B FWHM / FWTM 13.0° / 27.0° Efficiency 93 % Peak intensity 11.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW3x9A FWHM / FWTM 12.0° / 25.0° Efficiency 89 % Peak intensity 11.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW519A FWHM / FWTM 14.0° / 30.0° Efficiency 92 % Peak intensity 9.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (MEASURED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 8.6° / 19.0° Efficiency 92 % Peak intensity 20.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 150 FWHM / FWTM 5.0° / 13.0° Efficiency 90 % Peak intensity 41.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 80 FWHM / FWTM 5.0° / 14.0° Efficiency 91 % Peak intensity 37.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (MEASURED): LED LH181A FWHM / FWTM 6.0° / 19.0° Efficiency 80 % Peak intensity 15.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM 10.0° / 25.0° Efficiency 88 % Peak intensity 12.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22P FWHM / FWTM 10.0° / 24.0° Efficiency 84 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED XP-E2 FWHM / FWTM 8.0° / 16.0° Efficiency 93 % Peak intensity 38.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM 10.0° / 20.0° Efficiency 94 % Peak intensity 22.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 12.0° / 26.0° Efficiency 91 % Peak intensity 13.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED XP-G3 FWHM / FWTM 12.0° / 25.0° Efficiency 91 % Peak intensity 13.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-P FWHM / FWTM 6.0° / 14.0° Efficiency 93 % Peak intensity 48.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HD FWHM / FWTM 6.7° / 14.0° Efficiency 91 % Peak intensity 41.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED XQ-E HD FWHM / FWTM 7.1° / 15.0° Efficiency 92 % Peak intensity 38.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 6.0° / 14.0° Efficiency 92 % Peak intensity 48.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 6.0° / 14.0° Efficiency 92 % Peak intensity 52.1 cd/lm LEDs/each optic 1 Light colour/type Red Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED LUXEON HL1Z FWHM / FWTM 6.0° / 18.0° Efficiency 88 % Peak intensity 26 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2X FWHM / FWTM 14.0° / 26.0° Efficiency 93 % Peak intensity 12.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2Z FWHM / FWTM 8.0° / 20.0° Efficiency 90 % Peak intensity 19.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED LUXEON IR Domed 60 (L1I0-0xxx060000000) FWHM / FWTM 9.0° / 23.0° Efficiency 93 % LEDs/each optic 1 Light colour/type IR Required components: LED LUXEON Rubix FWHM / FWTM 6.0° / 14.0° Efficiency 93 % Peak intensity 47.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON T FWHM / FWTM 11.0° / 22.0° Efficiency 93 % Peak intensity 17.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED LUXEON TX FWHM / FWTM 9.7° / 21.0° Efficiency 91 % Peak intensity 19.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Z ES FWHM / FWTM 8.0° / 16.0° Efficiency 92 % Peak intensity 32.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SST-12 FWHM / FWTM 8.0° / 16.0° Efficiency 92 % Peak intensity 34.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED SST-20 FWHM / FWTM 8.0° / 19.0° Efficiency 91 % Peak intensity 22.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 12.0° / 24.0° Efficiency 91 % Peak intensity 16.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 11.0° / 23.0° Efficiency 88 % Peak intensity 15.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3030 FWHM / FWTM 8.0° / 18.0° Efficiency 92 % Peak intensity 27.6 cd/lm LEDs/each optic 1 Light colour/type Blue Required components: LED OSCONIQ P 3737 Flat FWHM / FWTM 10.0° / 24.0° Efficiency 93 % Peak intensity 15.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Black Flat (LUW HWQP) FWHM / FWTM 8.0° / 16.0° Efficiency 90 % Peak intensity 26.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED OSLON Pure 1414 FWHM / FWTM 6.0° / 14.0° Efficiency 93 % Peak intensity 44 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 10.0° / 22.0° Efficiency 93 % Peak intensity 19.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square Flat FWHM / FWTM 8.7° / 19.0° Efficiency 91 % Peak intensity 21.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED OSLON Square Flat FWHM / FWTM 8.0° / 18.0° Efficiency 93 % Peak intensity 29.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square PC FWHM / FWTM 11.0° / 22.0° Efficiency 94 % Peak intensity 18.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 150 FWHM / FWTM 8.0° / 16.0° Efficiency 93 % Peak intensity 36.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED SFH 4715AS FWHM / FWTM 6.0° / 18.0° Efficiency 91 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4716AS FWHM / FWTM 6.5° / 15.0° Efficiency 92 % LEDs/each optic 1 Light colour/type IR Required components: LED LH351A FWHM / FWTM 9.0° / 20.0° Efficiency 91 % Peak intensity 21.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED LH351B FWHM / FWTM 10.0° / 23.0° Efficiency 92 % Peak intensity 17.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351D FWHM / FWTM 16.0° / 30.0° Efficiency 91 % Peak intensity 8.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351Z FWHM / FWTM 9.0° / 19.0° Efficiency 93 % LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P OPTICAL RESULTS (SIMULATED): LED Z5M1/Z5M2 FWHM / FWTM 10.0° / 20.0° Efficiency 93 % Peak intensity 19.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M4 FWHM / FWTM 12.0° / 26.0° Efficiency 94 % Peak intensity 12.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5P FWHM / FWTM 8.0° / 17.0° Efficiency 92 % Peak intensity 26.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/22 PRODUCT DATASHEET CA14505_G2-LXP2-RS2-P GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 10/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/22
CA14505_G2-LXP2-RS2-P 价格&库存
很抱歉,暂时无法提供与“CA14505_G2-LXP2-RS2-P”相匹配的价格&库存,您可以联系我们找货
  • 112+8.62693112+1.08225
  • 336+8.40573336+1.05450
  • 448+8.36149448+1.04895
  • 1120+8.184521120+1.02675
  • 1680+8.007561680+1.00455
库存:896
  • 112+13.00675112+1.63170
  • 224+12.82979224+1.60950
  • 336+12.76955336+1.60195
  • 448+12.74131448+1.59840
  • 560+12.56435560+1.57620
