CA14509_G2-LXP2-M-P
CA14509_G2-LXP2-M-P
    LEDIL(芬兰)
    LENSASSY1POS21.8MMRNDBLACK
CA14509_G2-LXP2-M-P 数据手册
PRODUCT DATASHEET CA14509_G2-LXP2-M-P G2-LXP2-M-P ~20° medium beam with light, black holder. Assembly with location pins and installation tape. SPECIFICATION: Dimensions Ø 21.8 mm Height 14.7 mm Fastening tape, pin ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length LXP2-M Single lens PMMA clear 21.6 LXP2-LT-HLD Holder PC black 21.6 HEIDI-TAPE Tape Acrylic foam black ORDERING INFORMATION: Component CA14509_G2-LXP2-M-P » Box size: Qty in box MOQ MPQ 1680 336 112 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.1 1/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (MEASURED): LED XP-E FWHM / FWTM 22.0° / 40.0° Efficiency 88 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HD FWHM / FWTM 24.0° / 44.0° Efficiency 86 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HD FWHM / FWTM 22.0° / 37.0° Efficiency 86 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (MEASURED): LED XQ-E HI FWHM / FWTM 21.0° / 37.0° Efficiency 85 % Peak intensity 6.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON C FWHM / FWTM 23.0° / 38.0° Efficiency 82 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 20.0° / 37.0° Efficiency 89 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (MEASURED): LED LUXEON V FWHM / FWTM 26.0° / 48.0° Efficiency 86 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V2 FWHM / FWTM 23.0° / 41.0° Efficiency 89 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxx19A FWHM / FWTM 22.0° / 40.0° Efficiency 86 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (MEASURED): LED NVSW219F FWHM / FWTM 23.0° / 40.0° Efficiency 90 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW319B FWHM / FWTM 24.0° / 43.0° Efficiency 90 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW3x9A FWHM / FWTM 24.0° / 44.0° Efficiency 86 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (MEASURED): LED NVSW519A FWHM / FWTM 18.0° / 37.0° Efficiency 86 % Peak intensity 5.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NWSx229A FWHM / FWTM 25.0° / 47.0° Efficiency 86 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Black Flat (LUW HWQP) FWHM / FWTM 20.0° / 38.0° Efficiency 87 % Peak intensity 6.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (MEASURED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 24.0° / 41.0° Efficiency 90 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH181A FWHM / FWTM 24.0° / 45.0° Efficiency 80 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH181B FWHM / FWTM 25.0° / 46.0° Efficiency 85 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (MEASURED): LED Z5M3 FWHM / FWTM 24.0° / 44.0° Efficiency 86 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22P FWHM / FWTM 26.0° / 46.0° Efficiency 81 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED J Series 2835 FWHM / FWTM 26.0° / 45.0° Efficiency 92 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM 25.0° / 41.0° Efficiency 93 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 26.0° / 45.0° Efficiency 90 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED XP-G3 FWHM / FWTM 26.0° / 45.0° Efficiency 89 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HD FWHM / FWTM 26.0° / 42.0° Efficiency 94 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 26.0° / 42.0° Efficiency 89 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED LUXEON HL2X FWHM / FWTM 26.0° / 46.0° Efficiency 91 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON IR Compact FWHM / FWTM 26.0° / 40.0° Efficiency 84 % LEDs/each optic 1 Light colour/type White Required components: LED LUXEON IR Domed 60 (L1I0-0xxx060000000) FWHM / FWTM 24.0° / 43.0° Efficiency 88 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED LUXEON IR Domed 60 (L1I0-0xxx060000000) FWHM / FWTM 24.0° / 42.0° Efficiency 88 % LEDs/each optic 1 Light colour/type White Required components: LED LUXEON IR Domed 90 (L1I0-0xxx090000000) FWHM / FWTM 26.0° / 44.0° Efficiency 90 % LEDs/each optic 1 Light colour/type White Required components: LED LUXEON T FWHM / FWTM 26.0° / 43.0° Efficiency 92 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED LUXEON TX FWHM / FWTM 26.0° / 43.0° Efficiency 91 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V2 FWHM / FWTM 26.0° / 43.0° Efficiency 91 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 25.0° / 44.0° Efficiency 88 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3030 FWHM / FWTM 23.0° / 42.0° Efficiency 91 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour/type Blue Required components: LED OSCONIQ P 3737 Flat FWHM / FWTM 26.0° / 46.0° Efficiency 92 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Black Flat (LUW HWQP) FWHM / FWTM 24.0° / 41.0° Efficiency 91 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED OSLON Pure 1414 FWHM / FWTM 26.0° / 39.0 + 42.0° Efficiency 93 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 150 FWHM / FWTM 26.0° / 42.0° Efficiency 93 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 80 FWHM / FWTM 27.0° / 40.0° Efficiency 91 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED SFH 4770S FWHM / FWTM 25.0° / 48.0° Efficiency 84 % LEDs/each optic 1 Light colour/type White Required components: LED LH181B FWHM / FWTM 26.0° / 45.0° Efficiency 90 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351A FWHM / FWTM 25.0° / 41.0° Efficiency 91 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED LH351B FWHM / FWTM 25.0° / 41.0° Efficiency 91 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M1/Z5M2 FWHM / FWTM 24.0° / 40.0° Efficiency 92 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M4 FWHM / FWTM 26.0° / 46.0° Efficiency 93 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED Z5P FWHM / FWTM 26.0° / 41.0° Efficiency 91 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED FWR1107MS FWHM / FWTM 24.0° / 44.0° Efficiency 89 % LEDs/each optic 1 Light colour/type IR Required components: LED FWR1108MS FWHM / FWTM 25.0° / 41.0° Efficiency 92 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED MFN1107MS FWHM / FWTM 25.0° / 42.0° Efficiency 88 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type IR Required components: LED MFN1108MS FWHM / FWTM 26.0° / 42.0° Efficiency 91 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type IR Required components: LED MGN1107MS FWHM / FWTM 25.0° / 42.0° Efficiency 88 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P OPTICAL RESULTS (SIMULATED): LED MGN1108MS FWHM / FWTM 26.0° / 42.0° Efficiency 91 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type IR Required components: LED MJN1107MS FWHM / FWTM 25.0° / 42.0° Efficiency 92 % LEDs/each optic 1 Light colour/type IR Required components: LED MJN1108MS FWHM / FWTM 26.0° / 41.0° Efficiency 93 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/22 PRODUCT DATASHEET CA14509_G2-LXP2-M-P GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/22
CA14509_G2-LXP2-M-P 价格&库存
很抱歉,暂时无法提供与“CA14509_G2-LXP2-M-P”相匹配的价格&库存,您可以联系我们找货
CA14509_G2-LXP2-M-P
  • 112+10.38320112+1.29870
  • 336+10.20571336+1.27650
  • 560+10.15780560+1.27051
  • 1680+10.028221680+1.25430
  • 2800+9.939472800+1.24320
CA14509_G2-LXP2-M-P
  • 112+13.04556112+1.63170
  • 224+12.86807224+1.60950
  • 336+12.80765336+1.60195
  • 448+12.77932448+1.59840
  • 560+12.60183560+1.57620
CA14509_G2-LXP2-M-P
    • 112+8.83016112+1.10445
    • 336+8.60830336+1.07670
    • 448+8.56392448+1.07115
    • 1120+8.386431120+1.04895
    • 1680+8.208941680+1.02675
