CN12298_LENA-W-DL
CN12298_LENA-W-DL
    LEDIL(芬兰)
    Reflector Mega Zenigata 14° Wide Round, 111mm
CN12298_LENA-W-DL 数据手册
PRODUCT DATASHEET Lena series last update 14/12/2012 Ordering number CN12296_LENA-S-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Mega Zenigata (GW5DGC) Metal 111 mm 85.6 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 14 degrees 80 % Available FWHM Efficiency cd/lm Gerber File 21 degrees 79 % Available FWHM Efficiency cd/lm Gerber File 44 degrees 75 % Available Ordering number CN12297_LENA-M-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Mega Zenigata (GW5DGC) Metal 111 mm 85.6 mm Round PC PC Screw Ready Ordering number CN12298_LENA-W-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Mega Zenigata (GW5DGC) Metal 111 mm 85.6 mm Round PC PC Screw Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. May 29th 2013 18:41 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena series last update 14/12/2012 GENERAL INFORMATION - Product series especially designed & optimized for Mega Zenigata (GW5DGC) series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). May 29th 2013 18:41 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 4 4 R9 A R1 43 Isometric view .6 7 Bottom view Detail A 3 w/o lens Lena reflector 86.95 89 3 Lena_lens (optional) Front view Lena base MEZ 11 1 2 2 Top view This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 DRAWN BY ah DATE Ledil Oy Salorankatu 10 FIN-24100 SALO Finland DRAWING TITLE Datasheet Lena-MEZ 14.12.2012 CHECKED BY pl DATE 14.12.2012 DESIGNED BY pl DATE 14.12.2012 D SIZE DRAWING NUMBER A4 SCALE 1:2 WEIGHT(g) REV - 2 SHEET A 1/1 1
CN12298_LENA-W-DL 价格&库存
很抱歉,暂时无法提供与“CN12298_LENA-W-DL”相匹配的价格&库存,您可以联系我们找货
