FCN10797_LD1-REC
FCN10797_LD1-REC
    LEDIL(芬兰)
    LENS LD1 RECT DRAGON 40X24DEG
FCN10797_LD1-REC 数据手册
PRODUCT DATASHEET Leila series last update 12/4/2013 Ordering number FCN11456_LD1-M2 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Diamond Dragon White 21.6 mm 15.4 mm Round PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File (simulated) 28 (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 8 degrees (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 14 degrees (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 24 degrees (simulated) 0 % Available Ordering number FCN10796_LD1-RS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Diamond Dragon White 21.6 mm 15.4 mm Round PMMA PC Glue Ready Ordering number FCN10798_LD1-D Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Diamond Dragon White 21.6 mm 15.4 mm Round PMMA PC Glue Ready Ordering number FCN10795_LD1-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Diamond Dragon White 21.6 mm 15.4 mm Round PMMA PC Glue Ready September 30th 2013 18:37 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Leila series last update 12/4/2013 Ordering number FCN10797_LD1-REC Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Diamond Dragon White 21.6 mm 15.4 mm Round PMMA PC Glue Ready FWHM Efficiency cd/lm Gerber File 40+24 degrees (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 40+14 degrees (simulated) 0 % Available Ordering number FCN11107_LD1-O-90 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Diamond Dragon White 21.6 mm 15.4 mm Round PMMA PC Glue Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. September 30th 2013 18:37 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Leila series last update 12/4/2013 GENERAL INFORMATION - Product series especially designed & optimized for Diamond Dragon series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf - Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue options. http://www.ledil.com/datasheets/DataSheet_GLUES.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the glue. NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. September 30th 2013 18:37 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 4 21 2 15.4 3 Lens 3 Holder Materials: Lens PMMA Holder PC 2 This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 4 .6 DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE Led Teh FIN Fin DRAWING TITLE pv 26.03.2010 tk 29.04.2009 HH 21.02.2008 D SIZE Datasheet LD1-Series Assy DRAWING NUMBER REV 1 A4 SCALE 2:1 WEIGHT(g) SHEET A 1/1 1
FCN10797_LD1-REC 价格&库存
很抱歉,暂时无法提供与“FCN10797_LD1-REC”相匹配的价格&库存,您可以联系我们找货
