C12476_MIRELLA-50-S
C12476_MIRELLA-50-S
    LEDIL(芬兰)
    REFLECTOR 1POS 49.9MM RND 24MM
C12476_MIRELLA-50-S 数据手册
PRODUCT DATASHEET C12476_MIRELLA-50-S MIRELLA-50-S ~15° spot beam SPECIFICATION: Dimensions Ø 49.9 mm Height 24 mm Fastening glue ROHS compliant yes MATERIALS: Component Type Material Colour MIRELLA-50-S Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C12476_MIRELLA-50-S » Box size: 480 x 280 x 300 mm Qty in box 336 MOQ MPQ 112 28 Box weight (kg) 3.0 Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/30 PRODUCT DATASHEET C12476_MIRELLA-50-S See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED BXRA LS FWHM / FWTM 18.0° / 48.0° Efficiency 83 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED BXRA LS FWHM / FWTM 13.0° / 27.0° Efficiency 89 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED BXRA LS FWHM / FWTM 14.0° / 28.0° Efficiency 84 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CLL01x FWHM / FWTM 20.0° / 56.0° Efficiency % LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED CLL01x FWHM / FWTM 17.0° / 32.0° Efficiency 84 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED CLL02x/CLU02x (LES10) FWHM / FWTM 19.0° / 50.0° Efficiency 84 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 32.0° / 70.0° Efficiency 81 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL LED CLL02x/CLU02x (LES10) FWHM / FWTM 28.0° / 67.0° Efficiency 82 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED CLL02x/CLU02x (LES10) FWHM / FWTM 20.0° / 48.0° Efficiency 93 % LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CLU700/701/702/703 FWHM / FWTM 26.0° / 64.0° Efficiency 83 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL LED CLU700/701/702/703 FWHM / FWTM 21.0° / 59.0° Efficiency 84 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED CLU700/701/702/703 FWHM / FWTM 15.0° / 32.0° Efficiency 90 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CLU700/701/702/703 FWHM / FWTM 15.0° / 32.0° Efficiency 85 % Peak intensity 5.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED CLU710/711 FWHM / FWTM 26.0° / 67.0° Efficiency 83 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED CLU710/711 FWHM / FWTM 20.0° / 54.0° Efficiency 85 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CLU710/711 FWHM / FWTM 29.0° / 69.0° Efficiency 83 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL LED CLU710/711 FWHM / FWTM 20.0° / 49.0° Efficiency 90 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLU720/721/723 FWHM / FWTM 32.0° / 73.0° Efficiency 83 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CLU720/721/723 FWHM / FWTM 24.0° / 68.0° Efficiency 90 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLU720/721/723 FWHM / FWTM 30.0° / 71.0° Efficiency 82 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED CLU720/721/723 FWHM / FWTM 25.0° / 66.0° Efficiency 85 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CXA/B 13xx FWHM / FWTM 15.0° / 36.0° Efficiency 81 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED CXA/B 13xx FWHM / FWTM 12.0° / 25.0° Efficiency 87 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CXA/B 13xx FWHM / FWTM 12.0° / 25.0° Efficiency 82 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 19.0° / 47.0° Efficiency 84 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED CXA/B 15xx FWHM / FWTM 20.0° / 60.0° Efficiency 90 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED CXA/B 15xx FWHM / FWTM 16.0° / 38.0° Efficiency 93 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 23.0° / 68.0° Efficiency 89 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 25.0° / 68.0° Efficiency 83 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 26.0° / 68.0° Efficiency 83 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED MHD-E/G FWHM / FWTM 18.0° / 40.0° Efficiency 89 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED MHD-E/G FWHM / FWTM 16.0° / 35.0° Efficiency 94 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MHD-E/G FWHM / FWTM 20.0° / 57.0° Efficiency 88 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED MT-G2 FWHM / FWTM 20.0° / 50.0° Efficiency 85 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED MT-G2 FWHM / FWTM 17.0° / 35.0° Efficiency 92 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MT-G2 FWHM / FWTM 18.0° / 37.0° Efficiency 85 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED XHP50 FWHM / FWTM 14.0° / 30.0° Efficiency 86 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED XHP50 FWHM / FWTM 14.0° / 28.0° Efficiency 92 % Peak intensity 7.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP50 FWHM / FWTM 17.0° / 44.0° Efficiency 85 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED XHP70 FWHM / FWTM 17.0° / 34.0° Efficiency 90 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP70 FWHM / FWTM 19.0° / 44.0° Efficiency 86 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XHP70 FWHM / FWTM 18.0° / 36.0° Efficiency 86 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1202/1203 FWHM / FWTM 20.0° / 49.0° Efficiency 89 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CoB 1202/1203 FWHM / FWTM 21.0° / 52.0° Efficiency 86 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED LUXEON CoB 1202/1203 FWHM / FWTM 23.0° / 60.0° Efficiency 85 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED LUXEON S1000 FWHM / FWTM 14.0° / 37.0° Efficiency 84 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED LUXEON S1000 FWHM / FWTM 21.0° / 60.0° Efficiency % LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED LUXEON S1000 FWHM / FWTM 17.0° / 38.0° Efficiency % LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED CxM-9 (13.5x13.5) FWHM / FWTM 21.0° / 53.0° Efficiency 90 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CxM-9 (13.5x13.5) FWHM / FWTM 24.0° / 63.0° Efficiency 84 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED COB L-Type (LES 9) FWHM / FWTM 20.0° / 48.0° Efficiency 90 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 9) FWHM / FWTM 23.0° / 59.0° Efficiency 86 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED COB L-Type (LES 9) FWHM / FWTM 22.0° / 53.0° Efficiency 87 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED NFMW48xA FWHM / FWTM 9.5° / 20.0° Efficiency 88 % Peak intensity 13.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED NSCxL036A FWHM / FWTM 17.0° / 37.0° Efficiency 84 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED NSCxL036A FWHM / FWTM 19.0° / 46.0° Efficiency 84 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED NSCxL036A FWHM / FWTM 17.0° / 35.0° Efficiency 88 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED Duris S10 FWHM / FWTM 20.0° / 57.0° Efficiency 81 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED Duris S10 FWHM / FWTM 15.0° / 33.0° Efficiency 89 % Peak intensity 6.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S10 FWHM / FWTM 15.0° / 33.0° Efficiency 83 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED Soleriq S13 FWHM / FWTM 27.0° / 70.0° Efficiency 87 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Soleriq S13 FWHM / FWTM 28.0° / 69.0° Efficiency 82 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED Soleriq S13 FWHM / FWTM 30.0° / 70.0° Efficiency 83 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED ZC4/6 FWHM / FWTM 21.0° / 56.0° Efficiency 83 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED ZC4/6 FWHM / FWTM 18.0° / 42.0° Efficiency 88 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED ZC4/6 FWHM / FWTM 19.0° / 44.0° Efficiency 82 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED Mini Zenigata (GW5BM) FWHM / FWTM 17.0° / 39.0° Efficiency 92 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Mini Zenigata (GW5BM) FWHM / FWTM 20.0° / 54.0° Efficiency 86 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED Mini Zenigata (GW6BM) FWHM / FWTM 17.0° / 41.0° Efficiency 91 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (MEASURED): LED Mini Zenigata (GW6BM) FWHM / FWTM 20.0° / 56.0° Efficiency 84 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (SIMULATED): LED LUXEON 7070 FWHM / FWTM 14.0° / 27.0° Efficiency 96 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V FWHM / FWTM 7.7° / 17.0° Efficiency 89 % Peak intensity 18.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NV4x144A FWHM / FWTM 12.0° / 22.0° Efficiency 90 % Peak intensity 11.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 11.0° / 21.0° Efficiency 91 % Peak intensity 12.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Soleriq S9 FWHM / FWTM 21.0° / 55.0° Efficiency 86 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED Soleriq S9 FWHM / FWTM 19.0° / 44.0° Efficiency 91 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/30 PRODUCT DATASHEET C12476_MIRELLA-50-S OPTICAL RESULTS (SIMULATED): LED Soleriq S9 FWHM / FWTM 20.0° / 48.0° Efficiency 87 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/30 PRODUCT DATASHEET C12476_MIRELLA-50-S GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/30
C12476_MIRELLA-50-S 价格&库存
很抱歉,暂时无法提供与“C12476_MIRELLA-50-S”相匹配的价格&库存,您可以联系我们找货
C12476_MIRELLA-50-S
  • 1+18.692811+2.41820
  • 5+16.509075+2.13570
  • 25+16.2470225+2.10180
库存:67
C12476_MIRELLA-50-S
  • 28+20.29761
  • 56+19.78942
  • 112+19.48533
库存:204
C12476_MIRELLA-50-S
  • 1+18.73359
  • 5+16.56557
  • 25+16.26612
库存:67
C12476_MIRELLA-50-S
库存:204
