CN13990_SAGA-HB-IP-WHT
    LEDIL(芬兰)
    Lens White 47° ~ 63° Screw
CN13990_SAGA-HB-IP-WHT 数据手册
PRODUCT DATASHEET SAGA-HB-IP-WHT SAGA-HB-IP-WHT ~60° high bay beam SPECIFICATION: Dimensions Ø 50.0 mm Height 12 mm Fastening screw Ingress protection classes ROHS compliant IP67 yes MATERIALS: Component Type Material Colour Finish Length C13586_SAGA-HB-IP Single lens Silicone clear 37.0 C13591_SAGA-FRAME-WHT Holder HRPC white 50.0 ORDERING INFORMATION: Quantities for one set: Single lens 1 Holder 1 Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/17 PRODUCT DATASHEET SAGA-HB-IP-WHT Component Qty in box MOQ MPQ Box weight (kg) C13586_SAGA-HB-IP » Box size: 480 x 280 x 300 mm Single lens 650 52 26 4.7 C13591_SAGA-FRAME-WHT » Box size: 480 x 280 x 300 mm Holder 900 52 26 6.5 Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/17 PRODUCT DATASHEET SAGA-HB-IP-WHT See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED V10 Gen6 FWHM / FWTM 58.0° / 106.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED V6 Gen6 FWHM / FWTM 73.0° / 115.0° Efficiency 88 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED V8 Gen6 FWHM / FWTM 66.0° / 109.0° Efficiency 88 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED VERO10 FWHM / FWTM 58.0° / 101.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLL01x FWHM / FWTM 61.0° / 93.0° Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLL02x/CLU02x (LES10) FWHM / FWTM 47.0° / 95.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 434 Typ L6 Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 58.0° / 98.0° Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLL03x/CLU03x FWHM / FWTM 61.0° / 125.0° Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 433 Typ L6 LED CLL03x/CLU03x FWHM / FWTM 64.0° / 116.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED CLU700/701/702/703 FWHM / FWTM 46.0° / 82.0° Efficiency 86 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 434 Typ L6 LED CLU700/701/702/703 FWHM / FWTM 56.0° / 90.0° Efficiency 87 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLU710/711 FWHM / FWTM 62.0° / 107.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED CLU720/721/723 FWHM / FWTM 50.0° / 109.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 433 Typ L6 LED CLU720/721/723 FWHM / FWTM 61.0° / 113.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CXA/B 13xx FWHM / FWTM 70.0° / 104.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 64.0° / 104.0° Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CXA/B 15xx FWHM / FWTM 64.0° / 102.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 63.0° / 111.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED MHD-E/G FWHM / FWTM 60.0° / 105.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CoB 1202/1203 FWHM / FWTM 63.0° / 108.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CoB 1202s FWHM / FWTM 67.0° / 106.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED CxM-14 (19x19) FWHM / FWTM 66.0° / 121.0° Efficiency 88 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CxM-6 (12x13) FWHM / FWTM 66.0° / 104.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CXM-7 (13x13) FWHM / FWTM 64.0° / 105.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED CxM-9 (13.5x13.5) FWHM / FWTM 63.0° / 109.0° Efficiency 88 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S10 FWHM / FWTM 74.0° / 106.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Soleriq S13 FWHM / FWTM 61.0° / 110.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (MEASURED): LED MJT COB LES 6 FWHM / FWTM 46.0° / 79.0° Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 434 Typ L6 LED Mini Zenigata (GW6BM) FWHM / FWTM 62.0° / 100.0° Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (SIMULATED): LED LUXEON CoB Compact FWHM / FWTM 67.0° / 106.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CxM-14 (19x19) FWHM / FWTM 61.0° / 125.0° Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 433 Typ L6 LED CxM-9 (13.5x13.5) FWHM / FWTM 47.0° / 95.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 434 Typ L6 Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (SIMULATED): LED COB S-Type (LES 7) FWHM / FWTM 64.0° / 84.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Soleriq S9 FWHM / FWTM 56.0° / 87.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LC020C FWHM / FWTM 42.0° / 66.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 479 Typ L6 Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/17 PRODUCT DATASHEET SAGA-HB-IP-WHT OPTICAL RESULTS (SIMULATED): LED LC040C FWHM / FWTM 51.0° / 81.0° Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 480 Typ L6 LED ZC12/18 FWHM / FWTM 61.0° / 125.0° Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 433 Typ L6 LED ZC4/6 FWHM / FWTM 47.0° / 95.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 434 Typ L6 Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/17 PRODUCT DATASHEET SAGA-HB-IP-WHT GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 11/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/17
CN13990_SAGA-HB-IP-WHT 价格&库存
很抱歉,暂时无法提供与“CN13990_SAGA-HB-IP-WHT”相匹配的价格&库存,您可以联系我们找货
