F13840_ANGELA-XW
F13840_ANGELA-XW
    LEDIL(芬兰)
    REFLECTOR RND 119.5MM 74.5MM HT
F13840_ANGELA-XW 数据手册
PRODUCT DATASHEET ANGELA series last update 7/5/2014 DETAILS Product Number F13840_ANGELA-XW Family ANGELA Type Reflector Color white Diameter 119.5 mm Height 74.5 mm Style round Optic Material PC Holder Material Fastening Status ready ROHS Comliant Yes Date Updated 13/05/2014 OPTICAL PROPERTIES LED Viewing Angle PrevaLED Core Z4 LES19 71 degrees Light Beam Efficiency cd/lm connector 93 % 0.650 Z50 Optic Clip part n r. 2213194-1 TE LUXEON CoB 1208 71 degrees 93 % 0.600 - STARK SLE G3 LES19 71 degrees 93 % 0.600 - STARK SLE G3 LES23 71 degrees 93 % 0.600 - CXA35 72 degrees 94 % 0.610 50-2303CR + Angela(50 CXM-14 72 degrees 93 % 0.630 -2300AN) IDEAL TE: Solderless connec tor part nr 2213254-2 + Z50 WU-M-461 Optic Clip part nr. 2213194-1 TE 72 degrees 92 % 0.600 Z50 Optic Clip part n r. 2213194-1 TE WU-M-462 72 degrees 92 % 0.600 Z50 Optic Clip part n r. 2213194-1 TE LUXEON CoB 1204/1205 72 degrees 93 % 0.600 - Soleriq S13 72 degrees 93 % 0.630 Solderless connector Soleriq Optic Clip S19 part nr. 2213194-1 TE 72 degrees 92 % 0.630 WU-M-484 Optic Clip part nr. 2213194-1 TE 73 degrees 92 % 0.608 WU-M-485 73 degrees 92 % 0.600 part nr. 2213401-2 + Z50 Solderless connector part nr. 2213407-2 + Z50 Z50 Optic Clip part n r. 2213194-1 TE Z50 Optic Clip part n r. 2213194-1 TE WU-M-486 73 degrees 92 % 0.600 Z50 Optic Clip part n r. 2213194-1 TE WU-M-464 Ledil Oy Salorankatu 10 24240 SALO Finland 73 degrees 92 % 0.600 Z50 Optic Clip part n September 17th 2014 16:21 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 r. 2213194-1 TE http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET ANGELA series last update 7/5/2014 NSBxL121A/NFCxL060B 73 degrees 94 % 0.630 Solderless connector September 17th 2014 16:21 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET ANGELA series last update 7/5/2014 part nr. 180580-0005 Molex September 17th 2014 16:21 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 C D E F G H 4 1 . 19 5 2 3 35 WITH LEDIL WITH TYCO WITH LEDIL Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: Up to 30mm class F, otherwise class M. According to DIN ISO 2768-2 Form and position: class K THIRD ANGLE PROJECTION: 1 This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy." DRAWI SIZE A3 SCALE H G NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. GENERAL INFORMATION - Product series especially designed & optimized for series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (short term 100 degrees of Celcius / 212 degrees of Fahrenheit). Note! Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range.
F13840_ANGELA-XW 价格&库存
很抱歉,暂时无法提供与“F13840_ANGELA-XW”相匹配的价格&库存,您可以联系我们找货
F13840_ANGELA-XW
    库存:520
    F13840_ANGELA-XW
    • 40+72.1640640+9.37791
    F13840_ANGELA-XW
      库存:40
