PRODUCT
DATASHEET
FN14645_STELLA-T4
STELLA-T4
IESNA Type IV for wider roads and area lighting
like car parks and gardens. Compatible with up
to 23 mm LES size COBs. Variant with black
frame.
SPECIFICATION:
Dimensions
Height
Fastening
Ø 90.0 mm
26.9 mm
screw
Ingress protection classes
ROHS compliant
IP67
yes
MATERIALS:
Component
Type
Material
Colour
Finish
Length
STELLA-T4
Single lens
Silicone
clear
85.0
STELLA-FRAME
Holder
PA66
black
90.0
ORDERING INFORMATION:
Component
FN14645_STELLA-T4
» Box size: 480 x 280 x 300 mm
Qty in box
Single lens
135
MOQ
MPQ
135
15
Box weight (kg)
7.1
Last update: 13/05/2024
Subject to change without prior notice
Published: 13/09/2018
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
See also our general installation guide: www.ledil.com/installation_guide
2/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
OPTICAL RESULTS (MEASURED):
LED
V18 Gen7
FWHM / FWTM
Asymmetric
Efficiency
90 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour/type
White
Required components:
LED
V22 Gen7
FWHM / FWTM
Asymmetric
Efficiency
90 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
Bender Wirth: 431 Typ Z1
LED
VERO18
FWHM / FWTM
Asymmetric
Efficiency
93 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour/type
White
3/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
CLL04x/CLU04x
FWHM / FWTM
Asymmetric
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
CXA/B 1816 & CXA/B 1820 & CXA 1850
FWHM / FWTM
Asymmetric
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
CXA/B 1830
FWHM / FWTM
Asymmetric
Efficiency
89 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
C14305_STELLA-CLAMP-CXA15-18
4/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
CXA/B 25xx
FWHM / FWTM
Asymmetric
Efficiency
93 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
LUXEON CoB 1208
FWHM / FWTM
Asymmetric
Efficiency
93 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
LUXEON CoB 1211
FWHM / FWTM
Asymmetric
Efficiency
92 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
5/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
LUXEON CoB 1213/1216/1812
FWHM / FWTM
Asymmetric
Efficiency
92 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
CxM-14 (19x19)
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
CxM-18 (21.5x21.5)
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
6/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
COB J-Type
FWHM / FWTM
Asymmetric
Efficiency
92 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
Soleriq S13
FWHM / FWTM
Asymmetric
Efficiency
93 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
Soleriq S19
FWHM / FWTM
Asymmetric
Efficiency
93 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
7/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
LC016D / LC019D / LC026D / LC033D
FWHM / FWTM
Asymmetric
Efficiency
90 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
LC040D / LC060D / LC080D
FWHM / FWTM
Asymmetric
Efficiency
90 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
MJT COB LES 14.5
FWHM / FWTM
Asymmetric
Efficiency
90 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour/type
White
Bender Wirth: 433 Typ Z1
8/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
MJT COB LES 22
FWHM / FWTM
Asymmetric
Efficiency
89 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
9/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
OPTICAL RESULTS (SIMULATED):
LED
V10 Gen7
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
Bender Wirth: 486 Typ L1
LED
V13 Gen7
FWHM / FWTM
Asymmetric
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
Bender Wirth: 477 Typ Z1
LED
VERO18
FWHM / FWTM
Asymmetric
Efficiency
91 %
LEDs/each optic
1
Light colour/type
White
10/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
CLL03x/CLU03x
FWHM / FWTM
Asymmetric
Efficiency
93 %
LEDs/each optic
1
Light colour/type
White
LED
CLL04x/CLU04x
FWHM / FWTM
Asymmetric
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
LED
CXA/B 1830
FWHM / FWTM
Asymmetric
Efficiency
93 %
LEDs/each optic
1
Light colour/type
White
11/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
CXA/B 25xx
FWHM / FWTM
Asymmetric
Efficiency
92 %
LEDs/each optic
1
Light colour/type
White
LED
CXA/B 30xx
FWHM / FWTM
Asymmetric
Efficiency
LEDs/each optic
1
Light colour/type
White
LED
CxM-22 (28x28)
FWHM / FWTM
Asymmetric
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
12/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
LED
Fortimo SLM L23 + SLM holder (PI)
FWHM / FWTM
Asymmetric
Efficiency
92 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour/type
White
13/14
PRODUCT
DATASHEET
FN14645_STELLA-T4
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
Due to use of high power COB's with this product, special attention to proper
thermal design is highly recommended. LEDiL has no liability for direct,
indirect or consecutive damages arising from the LEDiL products being used
outside of the recommended temperature range.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Poznan, Poland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
14/14
很抱歉,暂时无法提供与“FN14645_STELLA-T4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 15+76.9198815+9.64590
- 45+76.3002745+9.56820
- 75+75.9462175+9.52380
- 225+75.32660225+9.44610
- 375+74.79551375+9.37950
- 国内价格
- 1+115.20608
- 2+88.01979
- 4+83.23702
- 国内价格 香港价格
- 1+123.721391+15.51490
- 5+110.024635+13.79730
- 10+96.2377610+12.06840
- 50+89.3893850+11.20960
- 国内价格 香港价格
- 15+97.2784215+12.19890
- 30+96.6588130+12.12120
- 45+96.3047545+12.07680
- 60+96.0392060+12.04350
- 75+95.1540575+11.93250
