C12480_MIRELLA-50-S-PIN
    LEDIL(芬兰)
    Reflector Cree XM-L, XT-E, XP-G 9° ~ 15° Spot Round, 49.9mm
C12480_MIRELLA-50-S-PIN 数据手册
PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN MIRELLA-50-S-PIN ~15° spot beam SPECIFICATION: Dimensions Ø 49.9 mm Height 23.9 mm Fastening pin ROHS compliant yes MATERIALS: Component Type Material Colour MIRELLA-50-S-PIN Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C12480_MIRELLA-50-S-PIN » Box size: 480 x 280 x 300 mm Qty in box 336 MOQ MPQ 112 28 Box weight (kg) 3.0 Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED SM4 FWHM / FWTM 15.0° / 32.0° Efficiency 81 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED MHB-A/B FWHM / FWTM 14.0° / 28.0° Efficiency 90 % Peak intensity 9.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MHB-A/B FWHM / FWTM 17.0° / 38.0° Efficiency 85 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED MHB-A/B FWHM / FWTM 16.0° / 32.0° Efficiency 85 % Peak intensity 7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED XHP50 FWHM / FWTM 22.0° / 60.0° Efficiency 86 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL LED XHP50 FWHM / FWTM 14.0° / 27.0° Efficiency 88 % Peak intensity 7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED XHP50 FWHM / FWTM 16.0° / 35.0° Efficiency 89 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XHP50 FWHM / FWTM 13.0° / 24.0° Efficiency 93 % Peak intensity 8.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L FWHM / FWTM 8.7° / 18.0° Efficiency 90 % Peak intensity 19.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED XM-L FWHM / FWTM 12.0° / 26.0° Efficiency 86 % Peak intensity 8.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XM-L FWHM / FWTM 12.0° / 24.0° Efficiency 85 % Peak intensity 11.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED XM-L RGBW (XMLCTW) FWHM / FWTM 21.0° / 58.0° Efficiency 84 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED XM-L2 FWHM / FWTM 8.6° / 18.0° Efficiency 91 % Peak intensity 18.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L2 FWHM / FWTM 12.0° / 26.0° Efficiency 86 % Peak intensity 8.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XP-G FWHM / FWTM 11.0° / 22.0° Efficiency 86 % Peak intensity 14.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED XP-G FWHM / FWTM 11.0° / 24.0° Efficiency 86 % Peak intensity 10.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XP-G FWHM / FWTM 8.1° / 16.0° Efficiency 91 % Peak intensity 25 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM 11.0° / 24.0° Efficiency 87 % Peak intensity 10.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED XP-G2 FWHM / FWTM 7.9° / 16.0° Efficiency 91 % Peak intensity 25.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HI FWHM / FWTM 7.7° / 16.0° Efficiency 90 % Peak intensity 24.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 10.0° / 22.0° Efficiency 84 % Peak intensity 14.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED XT-E FWHM / FWTM 11.0° / 24.0° Efficiency 85 % Peak intensity 9.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED XT-E FWHM / FWTM 7.6° / 16.0° Efficiency 89 % Peak intensity 24 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 11.0° / 21.0° Efficiency 93 % Peak intensity 11.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED LUXEON A FWHM / FWTM 10.0° / 22.0° Efficiency 85 % Peak intensity 14.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED LUXEON A FWHM / FWTM 12.0° / 28.0° Efficiency 85 % Peak intensity 8.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED LUXEON A FWHM / FWTM 8.9° / 18.0° Efficiency 89 % Peak intensity 20.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED LUXEON C FWHM / FWTM 22.0° / 51.0° Efficiency 81 % Peak intensity 3.1 cd/lm LEDs/each optic 4 Light colour/type RGBW Required components: C13723_MIRELLA-RZL LED LUXEON M/MX FWHM / FWTM 15.0° / 34.0° Efficiency 86 % Peak intensity 5.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED LUXEON M/MX FWHM / FWTM 12.0° / 26.0° Efficiency 91 % Peak intensity 10.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED LUXEON M/MX FWHM / FWTM 15.0° / 30.0° Efficiency 85 % Peak intensity 7.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED LUXEON MZ FWHM / FWTM 11.0° / 26.0° Efficiency 85 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED LUXEON MZ FWHM / FWTM 8.7° / 18.0° Efficiency 90 % Peak intensity 19.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED LUXEON Z FWHM / FWTM 18.0° / 51.0° Efficiency 82 % Peak intensity 3.4 cd/lm LEDs/each optic 4 Light colour/type RGBW Required components: C13723_MIRELLA-RZL LED NS9x383 FWHM / FWTM 9.2° / 15.0° Efficiency 89 % Peak intensity 17.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NS9x383 FWHM / FWTM 12.0° / 28.0° Efficiency 85 % Peak intensity 8.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED NV4x144A FWHM / FWTM 13.0° / 24.0° Efficiency 92 % Peak intensity 9.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S8 FWHM / FWTM 12.0° / 28.0° Efficiency 86 % Peak intensity 8.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL LED Duris S8 FWHM / FWTM 11.0° / 22.0° Efficiency 86 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED Duris S8 FWHM / FWTM 9.7° / 20.0° Efficiency 91 % Peak intensity 16 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square EC FWHM / FWTM 9.4° / 20.0° Efficiency 85 % Peak intensity 15.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL LED OSLON Square EC FWHM / FWTM 11.0° / 26.0° Efficiency 85 % Peak intensity 9.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12479_MIRELLA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 8.0° / 16.0° Efficiency 90 % Peak intensity 23.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Ostar-SMT RGB FWHM / FWTM 19.0° / 56.0° Efficiency 85 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL LED LH508A FWHM / FWTM 12.0° / 22.0° Efficiency 90 % Peak intensity 10.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (MEASURED): LED F50360 (RGB) FWHM / FWTM 21.0° / 55.0° Efficiency 84 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL LED F50360 (RGB) FWHM / FWTM 19.0° / 56.0° Efficiency 86 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13723_MIRELLA-RZL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (SIMULATED): LED XHP35 HD FWHM / FWTM 11.0° / 20.0° Efficiency 92 % Peak intensity 11.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5258 FWHM / FWTM 9.0° / 19.0° Efficiency 91 % Peak intensity 17 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 7070 FWHM / FWTM 11.0° / 22.0° Efficiency 87 % Peak intensity 10.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13333_MIRELLA-CL Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 10.0° / 21.0° Efficiency 92 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22P FWHM / FWTM 6.9° / 16.0° Efficiency 91 % Peak intensity 25.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/21 PRODUCT DATASHEET C12480_MIRELLA-50-S-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/21
C12480_MIRELLA-50-S-PIN 价格&库存
很抱歉,暂时无法提供与“C12480_MIRELLA-50-S-PIN”相匹配的价格&库存,您可以联系我们找货
  • 1+25.83655
  • 28+20.70996
  • 84+19.50018
  • 140+18.19458
库存:102
  • 1+25.768131+3.33350
  • 28+20.7018528+2.67810
  • 84+19.4789684+2.51990
  • 140+18.16871140+2.35040
库存:102
