CA10298_SPUTNIK-R5
CA10298_SPUTNIK-R5
    LEDIL(芬兰)
    Lens with Integrated Mount Clear 26° Medium Seoul P5 Adhesive
CA10298_SPUTNIK-R5 数据手册
LEDIL F’FORM OPTICS FULLY SEALABLE SPUTNIK-R lens for SSC P5 - - Use with Seoul Semiconductor P5 series of high power RGB LEDs Unique mixing of RGB colors inside the lens. Out comes a very homogeneous color. Lensmaterial optical grade PMMA with high UV and temperature resistance (105°C/220°F) Despite of the strong mixing of light, the lens has a high optical efficiency No lens holder. Fastening to heat sink with a PU foam adhesive tape of automotive grade Lens foot can be potted with resin without loosing anything in optical efficiency (fully sealed construction possible) Diameter 26 mm (approximately 1”) Easy build of a complete luminaire using SPUTNIK-R, P5 and heat sink Also possible to attach to P5 on the MCPCB offered by Seoul SC (F50381) Mechanical CAD models available upon request LENS TYPES NAME Sputnik-R Medium ORDERING CODE CA10298_Sputnik-R5 FWHM Angle ±13° © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS MEASUREMENT DATA SPUTNIK-R Relative Intensity 100% 75% 50% 25% 0% -20 -10 0 10 20 Angle, Degrees DIMENSIONS, POTTING & ASSEMBLY Potting with appropriate resin Position of P5 LED in the lens Seen from underneath © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28
CA10298_SPUTNIK-R5 价格&库存
很抱歉,暂时无法提供与“CA10298_SPUTNIK-R5”相匹配的价格&库存,您可以联系我们找货
