CA11768_LAURA-WW-RE
CA11768_LAURA-WW-RE
    LEDIL(芬兰)
CA11768_LAURA-WW-RE 数据手册
PRODUCT DATASHEET Laura series last update 26/3/2012 Ordering number CX11645 Description CA11645_Laura-SS-RE-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel White 21.6 mm 12.9 mm Square PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File (simulated) 12 93 % Available FWHM Efficiency cd/lm Gerber File 7 degrees 93 % 33.500 Available FWHM Efficiency cd/lm Gerber File 12+40 degrees 92 % Available FWHM Efficiency cd/lm Gerber File 15 degrees 90 % 5.000 Available Ordering number CX11352 Description CA11352_Laura-RS-RE-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel White 21.6 mm 13.1 mm Square PMMA PC Tape Ready Ordering number CX11364 Description CA11364-Laura-O-RE-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel White 21.6 mm 13.1 mm Square PMMA PC Tape Ready Ordering number CX11359 Description CA11359-Laura-D-RE-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel White 21.6X21.6 mm 12.9 mm Square PMMA PC Tape Ready April 4th 2012 11:10 Copyright Ledil Oy - Subject to change without prior notice - Page 1/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura series last update 26/3/2012 Ordering number CX11354 Description CA11354_Laura-M-RE-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel White 21.6 mm 13.1 mm Square PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File 28 degrees 88 % 2.700 Available FWHM Efficiency cd/lm Gerber File 44 degrees 88 % Available FWHM Efficiency cd/lm Gerber File 66 degrees 93 % Available Ordering number CX12568 Description CX12568_LAURA-W-WHT Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel White 21.6 mm 12.9 mm Square PMMA PC Tape Ready Ordering number CA11768 Description CA11768_Laura-WW-RE-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel White 21.6 mm 12.9 mm Square PMMA PC Tape Ready Ordering number CX11524 Description CA11524_Laura-Refl-W-RE-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Reflector LUXEON Rebel White 21.6 mm 12.9 mm Square PC PC Tape Ready FWHM Efficiency cd/lm Gerber File 68 degrees 81 % Available April 4th 2012 11:10 Copyright Ledil Oy - Subject to change without prior notice - Page 2/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura series last update 26/3/2012 NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. April 4th 2012 11:10 Copyright Ledil Oy - Subject to change without prior notice - Page 3/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura series last update 26/3/2012 GENERAL INFORMATION - Product series especially designed & optimized for LUXEON Rebel series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. April 4th 2012 11:10 Copyright Ledil Oy - Subject to change without prior notice - Page 4/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 4 Bottom view 21.6 4 Oval-version beam direction 3 3 Optic 12.9 Holder Front view Tape 2 2 Materials lens: PMMA holder: PC White Tape: PU Foam 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE Led Teh FIN Fin DRAWING TITLE pv 02.08.2010 sn 22.07.2010 DESIGNED BY hh DATE 21.01.2010 D SIZE Assy Datasheet Laura-tape series DRAWING NUMBER A4 SCALE 2:1 WEIGHT(g) REV CA11352 1 SHEET A 1/1 1
CA11768_LAURA-WW-RE 价格&库存
很抱歉,暂时无法提供与“CA11768_LAURA-WW-RE”相匹配的价格&库存,您可以联系我们找货
