CA12158_LENA-W_BXRA
CA12158_LENA-W_BXRA
    LEDIL(芬兰)
CA12158_LENA-W_BXRA 数据手册
PRODUCT DATASHEET Lena-BXRA-ES series Ordering number CA12164 Description CA12164_Lena-M_BXRA Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector BXRA-C0800/1200/2000 Metal 111 mm 86.2 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 19 degrees Available FWHM Efficiency cd/lm Gerber File 10 degrees Available Ordering number CA12157 Description CA12157_Lena-S_BXRA Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector BXRA-C0800/1200/2000 Metal 111 mm 86.2 mm Round PC PC Screw Ready Ordering number CA12159 Description CA12159_Lena-S-Diffuser-Lens_BXRA Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector BXRA-C0800/1200/2000 Metal 111 mm 87.8 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 11 degrees Available Ordering number CA12168 Description CA12168_Lena-M-Diffuser-Lens_BXRA Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector BXRA-C0800/1200/2000 Metal 111 mm 87.8 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 20 degrees Available February 13th 2012 16:24 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena-BXRA-ES series Ordering number CA12158 Description CA12158_Lena-W_BXRA Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector BXRA-C0800/1200/2000 Metal 111 mm 86.2 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 44 degrees Available Ordering number CA12160 Description CA12160_Lena-W-Diffuser-Lens_BXRA Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector BXRA-C0800/1200/2000 Metal 111 mm 87.8 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 46 degrees Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. February 13th 2012 16:24 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena-BXRA-ES series GENERAL INFORMATION - Product series especially designed & optimized for BXRA-C0800/1200/2000 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). February 13th 2012 16:24 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D . 94 4 4 4 11 1 6.25 3 86.2 H Reflector material PC Metal plated with clear lacquer 3 43 .7 19 3 2 58 Base material PC, white .6 2 26 3. .9 2 NOTE: using optional sublens, add 1.6mm to dimension H. 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE pl 13.07.2011 CHECKED BY DATE pl 26.04.2011 DESIGNED BY DATE pl 01.04.2011 D Ledil Oy Salorankatu 10 FIN-24240 SALO Finland DRAWING TITLE Datasheet Lena-BXRA-assembly SIZE DRAWING NUMBER A4 SCALE 1:2 WEIGHT(g) REV -- 1 SHEET A 1/1 1
CA12158_LENA-W_BXRA 价格&库存
很抱歉,暂时无法提供与“CA12158_LENA-W_BXRA”相匹配的价格&库存,您可以联系我们找货
