CS14895_HB-IP-2X6-RS
    LEDIL(芬兰)
CS14895_HB-IP-2X6-RS 数据手册
PRODUCT DATASHEET CS14895_HB-IP-2X6-RS HB-IP-2X6-RS ~20° spot beam SPECIFICATION: Dimensions Height Fastening 173.0 x 71.4 mm 11.4 mm pin, screw Ingress protection classes ROHS compliant IP67 yes MATERIALS: Component Type Material Colour HB-IP-2X6-RS Multi-lens PMMA clear 2X6-SEAL25 Seal Silicone white Finish ORDERING INFORMATION: Component CS14895_HB-IP-2X6-RS » Box size: 476 x 273 x 247 mm Qty in box Multi-lens 120 MOQ MPQ 40 40 Box weight (kg) 8.0 Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED QUICK FLUX 2x6 LED XG xxx G7+ FWHM / FWTM 16.0° / 33.0° Efficiency 94 % Peak intensity 7.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED QUICK FLUX 2x6 LED XT xxx G5 FWHM / FWTM 13.0° / 26.0° Efficiency 94 % Peak intensity 10.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L FWHM / FWTM 21.0° / 38.0° Efficiency 94 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 13.0° / 27.0° Efficiency 94 % Peak intensity 10.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED XP-L HD FWHM / FWTM 20.0° / 37.0° Efficiency 93 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM 22.0° / 43.0° Efficiency 93 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E HE FWHM / FWTM 13.0° / 26.0° Efficiency 94 % Peak intensity 11.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 15.0° / 29.0° Efficiency 94 % Peak intensity 8.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED LUXEON V FWHM / FWTM 20.0° / 41.0° Efficiency 92 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V2 FWHM / FWTM 15.0° / 30.0° Efficiency 94 % Peak intensity 8.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-TX (L2T0-xxxx012M0000) FWHM / FWTM 14.0° / 27.0° Efficiency 92 % Peak intensity 10.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED SST-10-B130 FWHM / FWTM 12.0° / 22.0° Efficiency 94 % Peak intensity 15.6 cd/lm LEDs/each optic 1 Light colour Deep Red Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED RecLED 146x45mm 2900lm 730 2x6 IP G1 FWHM / FWTM 14.0° / 27.0° Efficiency 95 % Peak intensity 10.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219D FWHM / FWTM 16.0° / 30.0° Efficiency 94 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 16.0° / 31.0° Efficiency 8% Peak intensity 94 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW319B FWHM / FWTM 18.0° / 34.0° Efficiency 94 % Peak intensity 6.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED NVSW3x9A FWHM / FWTM 19.0° / 36.0° Efficiency 92 % Peak intensity 5.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW519A FWHM / FWTM 20.0° / 37.0° Efficiency 95 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 13.0° / 33.0° Efficiency 94 % Peak intensity 8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 16.0° / 32.0° Efficiency 92 % Peak intensity 7.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 13.0° / 24.0° Efficiency 94 % Peak intensity 12 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x6 DP G4 FWHM / FWTM 13.0° / 27.0° Efficiency 94 % Peak intensity 10.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x6 DP G5 FWHM / FWTM 14.0° / 26.0° Efficiency 96 % Peak intensity 10.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RH12 (LH351C) FWHM / FWTM 17.0° / 31.0° Efficiency 94 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED BALAM-VP-5250-750-36 FWHM / FWTM 22.0° / 50.0° Efficiency 95 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED BALAMEC-VE-5700-740-36 FWHM / FWTM 23.0° / 50.0° Efficiency 96 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XLE-S22C4XTEHE (XT-E HE) FWHM / FWTM 13.0° / 26.0° Efficiency 94 % Peak intensity 11.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XLE-S26XHP35 (XHP35 HD) FWHM / FWTM 24.0° / 45.0° Efficiency 94 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED 2x6 5050 module - SMJD-3625012F-XX FWHM / FWTM 24.0° / 53.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED SMJQ-D36W12Mx FWHM / FWTM 15.0° / 39.0° Efficiency 89 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED SMJQ-D36W12Px FWHM / FWTM 16.0° / 36.0° Efficiency 93 % Peak intensity 6.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM 14.0° / 26.0° Efficiency 94 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED Z5M3 FWHM / FWTM 16.0° / 33.0° Efficiency 95 % Peak intensity 7.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM 15.0° / 39.0° Efficiency 89 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 17.0° / 34.0° Efficiency 92 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE 2x6 3000lm HP EXC2 OTD FWHM / FWTM 13.0° / 25.0° Efficiency 94 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (MEASURED): LED RLE 2x6 4500lm HP HE EXC3 OTD Z19 FWHM / FWTM 24.0° / 50.0° Efficiency 96 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (SIMULATED): LED J Series 5050 Round LES FWHM / FWTM 25.0° / 51.0° Efficiency 94 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 5050B 6V K Class FWHM / FWTM 24.0° / 52.0° Efficiency 94 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-H FWHM / FWTM 12.0° / 28.0° Efficiency 92 % Peak intensity 10.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HD FWHM / FWTM 22.0° / 46.0° Efficiency 93 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (SIMULATED): LED XHP35 HI FWHM / FWTM 16.0° / 32.0° Efficiency 93 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35.2 HD FWHM / FWTM 26.0° / 48.0° Efficiency 92 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 11.0° / 26.0° Efficiency 91 % Peak intensity 14.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM 17.0° / 35.0° Efficiency 93 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (SIMULATED): LED XP-G4 FWHM / FWTM 14.0° / 26.0° Efficiency 93 % Peak intensity 10.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 8.0° / 19.0° Efficiency 92 % Peak intensity 21.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 23.0° / 50.0° Efficiency 91 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Square LES FWHM / FWTM 25.0° / 52.0° Efficiency 94 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (SIMULATED): LED LUXEON C FWHM / FWTM 10.0° / 23.0° Efficiency 91 % Peak intensity 17.3 cd/lm LEDs/each optic 1 Light colour Cyan Required components: LED NV4WB35AM FWHM / FWTM 22.0° / 40.0° Efficiency 94 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED PrevaLED Brick HP IP 2x6 FWHM / FWTM 14.0° / 28.0° Efficiency 92 % Peak intensity 10.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ C 2424 FWHM / FWTM 11.0° / 22.0° Efficiency 93 % Peak intensity 16.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3030 FWHM / FWTM 9.0° / 20.0° Efficiency 94 % Peak intensity 21.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM 12.0° / 25.0° Efficiency 89 % Peak intensity 13 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 19.0° / 37.0° Efficiency 93 % Peak intensity 6.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 Flat FWHM / FWTM 14.0° / 30.0° Efficiency 94 % Peak intensity 9.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 10.0° / 20.0° Efficiency 92 % Peak intensity 20.2 cd/lm LEDs/each optic 1 Light colour Far Red Required components: LED LH181B FWHM / FWTM 13.0° / 28.0° Efficiency 93 % Peak intensity 10.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH231B FWHM / FWTM 16.0° / 32.0° Efficiency 93 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351D FWHM / FWTM 22.0° / 40.0° Efficiency 93 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS OPTICAL RESULTS (SIMULATED): LED Z5M4 FWHM / FWTM 16.0° / 34.0° Efficiency 93 % Peak intensity 7.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22T FWHM / FWTM 15.0° / 33.0° Efficiency 93 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/20 PRODUCT DATASHEET CS14895_HB-IP-2X6-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 19/09/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/20
CS14895_HB-IP-2X6-RS 价格&库存
很抱歉,暂时无法提供与“CS14895_HB-IP-2X6-RS”相匹配的价格&库存,您可以联系我们找货
    库存:40
