CS16102_STRADELLA-IP-28-T3
    LEDIL(芬兰)
    LENS CLEAR ASYMMETRICAL SCREW
CS16102_STRADELLA-IP-28-T3 数据手册
PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 STRADELLA-IP-28-T3 IESNA Type III (medium) beam for roads that are equal to or wider than mounting height. Variant made from PMMA. SPECIFICATION: Dimensions Height 100.0 x 100.0 9.2 mm Fastening pin,screw Ingress protection classes IP66,IP67 ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length STRADELLA-IP-28-T3 Multi-lens PMMA clear 100.0 STRADELLA-28-SEAL Seal Silicone white 95.0 ORDERING INFORMATION: Component CS16102_STRADELLA-IP-28-T3 » Box size: 476 x 273 x 247 mm Qty in box Multi-lens 156 MOQ MPQ 78 78 Box weight (kg) 6.3 Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 See also our general installation guide: www.ledil.com/installation_guide Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (MEASURED): LED HiQLED STR28 CR JE2835 4x7 xxx FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiQLED STR28 CR JK3030 4x7 xxx FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED QUICK FLUX STR28 XD2x14 xxx G8 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (MEASURED): LED QUICK FLUX STR28 XP2x14 xxx G7 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED QUICK FLUX STR28 XT2x14 xxx G5 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED J Series 2835 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (MEASURED): LED J Series 3030 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED J Series 3030 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XD16 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (MEASURED): LED XP-G3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 3030 2D (Round LES) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (MEASURED): LED NF2W585AR FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NF2x757G FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219F FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (MEASURED): LED Duris S5 (2 chip) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ S 3030 (QSLR31) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (MEASURED): LED HiLOM SC28 (LH181B) FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiLOM SM28 (LM301B) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (SIMULATED): LED J Series 3030 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED J Series 3030C FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-E2 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (SIMULATED): LED XP-G FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON TX FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (SIMULATED): LED LUXEON V2 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NF2x757G FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219F FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (SIMULATED): LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 2424 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 3030 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (SIMULATED): LED OSLON Pure 1414 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 150 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (SIMULATED): LED LH231B FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M1/Z5M2 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 OPTICAL RESULTS (SIMULATED): LED Z8Y22P FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/17 PRODUCT DATASHEET CS16102_STRADELLA-IP-28-T3 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 12/04/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/17
物料型号: CS16102_STRADELLA-IP-28-T3
器件简介: - 产品名称:STRADELLA-IP-28-T3 - 描述:IESNA Type III (中等) 光束,适用于等于或大于安装高度的道路。由PMMA材料制成的变体。
引脚分配: - 固定方式:销钉或螺丝
参数特性: - 尺寸:100.0x100.0 mm - 高度:9.2 mm - 防护等级:IP66, IP67 - 符合RoHS标准:是
功能详解: - 光学结果(测量):提供了不同LED型号的FWHM/FWTM(远场半最大宽度/远场半总宽度)、不对称效率、峰值强度等信息。
应用信息: - 该产品适用于需要中等光束宽度的道路照明。
封装信息: - 材料:PMMA(聚甲基丙烯酸甲酯) - 颜色:透明 - 长度:100.0 mm
订购信息: - 每箱数量:156 - 最小起订量(MOQ):78 - 最大起订量(MPQ):78 - 箱重:6.3 kg - 包装尺寸:476x273x247 mm
CS16102_STRADELLA-IP-28-T3 价格&库存
很抱歉,暂时无法提供与“CS16102_STRADELLA-IP-28-T3”相匹配的价格&库存,您可以联系我们找货
