F14170_FLORENCE-ZT25
    LEDIL(芬兰)
F14170_FLORENCE-ZT25 数据手册
PRODUCT DATASHEET F14170_FLORENCE-ZT25 FLORENCE-ZT25 Double asymmetric beam for aisle and shelf lighting SPECIFICATION: Dimensions Height 286.0 x 61.0 mm 11 mm Fastening screw ROHS compliant yes MATERIALS: Component Type Material Colour FLORENCE-ZT25 Linear lens PMMA clear Finish ORDERING INFORMATION: Component F14170_FLORENCE-ZT25 » Box size: 398 x 298 x 140 mm Qty in box 60 MOQ 18 MPQ 6 Box weight (kg) 5.8 Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 See also our general installation guide: www.ledil.com/installation_guide Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (MEASURED): LED XH-B/G FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 2D (Round LES) FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3535 2D FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-3535L (L202 - xxxx033C30001) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (MEASURED): LED MP-2016 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757D FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757G FWHM / FWTM Asymmetric Efficiency % LEDs/each optic 1 Light colour White Required components: LED NFSW757H FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (MEASURED): LED PL-BAR-G3 1100 280x55 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED PLG2-BAR-1100-xxx-280x55-DC FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris E5 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S2 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (MEASURED): LED Duris S5 (Single chip) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 2226 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Line VO 1ft MF 3R HV5 FWHM / FWTM Asymmetric Efficiency 98 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (MEASURED): LED Fortimo LED Line 1ft 650lm 3R HV4 & LV4 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Line 1ft HF 3R HV5 FWHM / FWTM Asymmetric Efficiency 98 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Line 1ft LF 3R HV5 & LV5 FWHM / FWTM Asymmetric Efficiency 98 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Line 1ft MF 3R HV5 & LV5 FWHM / FWTM Asymmetric Efficiency 98 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (MEASURED): LED LM231 A/B FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM561B FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM561B Plus FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-R286A FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (MEASURED): LED SEOUL 3030 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL 5630C FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 3030 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LLE G2 55x280mm 2000lm FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (SIMULATED): LED XP-G FWHM / FWTM Asymmetric Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFSx757G FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: LED NFSx757G FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (SIMULATED): LED Duris E 2835 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris E 2835 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM28xB Series FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (SIMULATED): LED LM301B FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM301B FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.5 cd/lm LEDs/each optic 2 Light colour White Required components: LED LM302Z plus FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.5 cd/lm LEDs/each optic 2 Light colour White Required components: LED LM302Z plus FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 OPTICAL RESULTS (SIMULATED): LED SEOUL 5630D FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 3030C FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/14 PRODUCT DATASHEET F14170_FLORENCE-ZT25 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 14/11/2023 Subject to change without prior notice Published: 31/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/14
F14170_FLORENCE-ZT25 价格&库存
很抱歉,暂时无法提供与“F14170_FLORENCE-ZT25”相匹配的价格&库存,您可以联系我们找货
