FP11086_LISA2-RS-CLIP 数据手册
PRODUCT DATASHEET
Lisa2 series
last update 24/9/2013
Ordering number FP11086_LISA2-RS-CLIP
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa2
Assembly
LUXEON Rebel
Black
9.9 mm
6.6 mm
Round
PMMA
PC
Clips, glue
Ready
FWHM
Efficiency
cd/lm
Gerber File
18 degrees
89 %
Available
FWHM
Efficiency
cd/lm
Gerber File
25 degrees
90 %
Available
FWHM
Efficiency
cd/lm
Gerber File
36 degrees
90 %
1.800
Available
FWHM
Efficiency
cd/lm
Gerber File
48+19 degrees
83 %
2.150
Available
Ordering number FP11072_LISA2-M-CLIP
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa2
Assembly
LUXEON Rebel
Black
9.9 mm
6.6 mm
Round
PMMA
PC
Clips, glue
Ready
Ordering number FP11073_LISA2-W-CLIP
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa2
Assembly
LUXEON Rebel
Black
9.9 mm
6.6 mm
Round
PMMA
PC
Clips, glue
Ready
Ordering number FP11122_LISA2-O-CLIP
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa2
Assembly
LUXEON Rebel
Black
9.9 mm
6.6 mm
Round
PMMA
PC
Clips, glue
Ready
September 30th 2013 19:02 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Lisa2 series
Ordering number FP11858_LISA2-O-90-CLIP
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa2
Assembly
LUXEON Rebel
Black
9.9 mm
6.6 mm
Round
PMMA
PC
Clips, glue
Ready
FWHM
Efficiency
cd/lm
Gerber File
48+19 degrees
83 %
Available
FWHM
Efficiency
cd/lm
Gerber File
80 degrees
79 %
Available
Ordering number FP11952
Description
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa2
Assembly
LUXEON Rebel
Black
9.9 mm
6.6 mm
Round
PMMA
PC
Ready
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
September 30th 2013 19:02 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
PRODUCT DATASHEET
Lisa2 series
GENERAL INFORMATION
- Product series especially designed & optimized for LUXEON Rebel series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220
degrees of Fahrenheit). Allows use of high current and temperature conditions.
Please find more information about used material from below:
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf
- Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit).
- Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue
options.
http://www.ledil.com/datasheets/DataSheet_GLUES.pdf
NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end
product. For example, mechanical stress, vibration and holes on the surface of the circuit boar
weaken the strength of the glue.
NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If
cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED
manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other
electronics components on the PCB.
Further note that optical components shall not be cleaned with any chemicals - only micro fiber
cloth may be used to remove fingerprints or other traces from handling.
September 30th 2013 19:02 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
A
B
C
R1
D
8.6
4
R 1.
19
c/c PCB
hole
4
A
Detail A
Scale: 8:1
9
3
6.6
3
1.76
PCB
1.6
Holder
2
9
Bottom view
Scale: 4:1
Lens
2
PCB hole
Materials:
Lens PMMA
Holder PC
2
Front view
Scale: 4:1
This drawing is our property.
It can't be reproduced
or communicated without
our written agreement.
1
DRAWN BY
DATE
CHECKED BY
DATE
DESIGNED BY
DATE
Led
Teh
FIN
Fin
DRAWING TITLE
Datasheet Lisa2-clip16-Rebel series Assy
ah
20.7.2011
sn
20.7.2011
hh
19.10.2009
D
SIZE
DRAWING NUMBER
REV
2
A4
SCALE
4:1 WEIGHT(g)
SHEET
A
1/1
1
FP11086_LISA2-RS-CLIP 价格&库存
很抱歉,暂时无法提供与“FP11086_LISA2-RS-CLIP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+27.56543
- 20+26.73753
- 40+25.92004
- 100+25.36811
- 500+24.81097
