FP15073_ZORYA-SC-50
FP15073_ZORYA-SC-50
    LEDIL(芬兰)
    ASSEMBLYROUND1POS55MM(D)35
FP15073_ZORYA-SC-50 数据手册
PRODUCT DATASHEET Zorya series last update 10/3/2016 DETAILS Product Number FP15073_ZORYA-SC-50 Family Zorya Type Assembly Color clear Diameter 56 mm Height 29,1 mm Style round Optic Material Silicone Holder Material PC Fastening socket Status promotion ROHS Comliant Yes Date Updated 10/03/2016 OPTICAL PROPERTIES Viewing Light Effi- LED Angle Beam ciency CLL03x/CLU034/CLU036 sim: 253 Decorative... sim: 97 % sim: 0.121 BJB: 47.319.2021 CLU710 sim: 268 Decorative... sim: 98 % sim: 0.113 BJB: 47.319.2021 CLU720 sim: 265 Decorative... sim: 98 % sim: 0.111 BJB: 47.319.2021 CLL04x/CLU044/CLU046 sim: 165 Decorative... sim: 97 % sim: 0.153 BJB: 47.319.2030 CLU730 sim: 264 Decorative... sim: 98 % sim: 0.114 BJB: 47.319.2030 CXA/B 25xx cd/lm Connector sim: 240 Decorative... sim: 97 % sim: 0.130 BJB: 47.319.2040 CXA/B 1816 & CXA/B 1820 & CXA 1850 sim: 266 Decorative... sim: 95 % sim: 0.113 BJB: 47.319.2131 CXA/B 30xx sim: 242 Decorative... sim: 97 % sim: 0.131 BJB: 47.319.2151 LUXEON CoB 1204/1205 sim: 263 Decorative... sim: 97 % sim: 0.115 BJB: 47.319.2011 Mega Zenigata (GW5DGC) sim: 257 Decorative... sim: 96 % sim: 0.118 BJB: 47.319.2011 Mega Zenigata (GW6DME) sim: 250 Decorative... sim: 96 % sim: 0.130 BJB: 47.319.2011 ZC12/18 sim: 265 Decorative... sim: 97 % sim: 0.114 BJB: 47.319.2021 SLE G5 LES15 sim: 262 Decorative... sim: 97 % sim: 0.115 BJB: 47.319.2021 LUXEON CoB 1211 sim: 222 Decorative... sim: 92 % sim: 0.142 BJB: 47.319.2314 ZC25/40 sim: 166 Decorative... sim: 97 % sim: 0.155 BJB: 47.319.2030 BXRA ES Rectangle sim: 256 Decorative... sim: 98 % sim: 0.130 BJB: 47.319.2040 Soleriq S19 sim: 246 Decorative... sim: 97 % sim: 0.130 BJB: 47.319.2170 March 15th 2016 10:56 Copyright Ledil Oy - Subject to change without prior notice - Page 1/1 Ledil Oy Salorankatu 10 24240 SALO, Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 20.4 26.9 4 4 3 29.1 3 56 A A 2 2 INDEX PART NO DESCRIPTION 1 2 ZORYA-SC-50 LENS ZORYA-SC-50 ADAPTER Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: Up to 30mm class M, otherwise class C. According to DIN ISO 2768-2 Form and position: class L 1 THIRD ANGLE PROJECTION: This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy. COLOUR Silicone PC White Ledil Oy Salorankatu 10 FIN 24240 SALO Finland DRAWING TITLE ZORYA-SC-50_MECHMODEL SIZE A4 SCALE D MATERIAL 1 PART NUMBER ZORYA-SC-50 1:2 WEIGHT 26,55 g SHEET A 1/1 A B C D E F G H 7 8 Recommendations: DIN912 M3 screws Max. torque 0,8 Nm 8 1 7 Press adapter through connector keyholes. 6 6 2 1 2 5 PATENT PENDING 5 3 5 4 4 6 4 Recommendations for heatsink: Max. diameter 50mm for best optical performance Twist adapter clockwise until hooks adapt. Press down the lens until the inner ledge of lens adjusts entirely to the groove. 3 3 2 INDEX PART NO 1 2 3 4 5 6 3 4 1 This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy. G F C COLOUR Silicone PC white 2 Ledil Oy Salorankatu 10 FIN 24240 SALO Finland DRAWING TITLE FA15073_ZORYA-SC-50 SIZE PART NUMBER A2 SCALE H MATERIAL F15074 ZORYA-SC F15076 ZORYA-SC-ADAPTER-50 COB LED LES 6-24mm Connector BJB M3 screw DIN912 Heatsink Ø50mm Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: up to 30mm class M, otherwise class C According to DIN ISO 2768-2 Form and position: class L THIRD ANGLE PROJECTION: DESCRIPTION 1 FA15073 1:1 WEIGHT B - SHEET A 1/1 NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. GENERAL INFORMATION - Product series especially designed & optimized for series of LEDs. - Special care taken to make light distribution as uniform as possible. Note! Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range.
FP15073_ZORYA-SC-50 价格&库存
很抱歉,暂时无法提供与“FP15073_ZORYA-SC-50”相匹配的价格&库存,您可以联系我们找货
