50.620 PA/R7035
50.620 PA/R7035
    HYLEC
    HYLEC - 50.620 PA/R7035 - Cable Gland, M20 x 1.5, 5 mm, 13 mm, Nylon 6 (Polyamide 6), Grey
50.620 PA/R7035 数据手册
Nylon cable glands With built-in cable reducing insert Features & Benefits:• Wide sealing and clamping range • Incorporated ‘Top-Hat’ reducing sealing ring to cater for small cable diameters. • Integrated anchorage. • Easy-to-install. • Wide Temperature range • Protection gradeIP67 (min) Specification:Dome nut Sealing ring (outer) Sealing ring (inner) Gland body Connecting thread Temperature range Protection Test std VDE licence UL / CSA-File SEV licence Polyamide PA6 V-2 Polychloroprene-Nitrile rubber CR/NBR Evoprene TPE Polyamide PA6 V-2 metric as per EN 60423 -20°C / +100°C EN 50262 / UL 514B 132752 E140310 01.1135 Part Numbers / colours A M16x1.5 M20x1.5 M25x1.5 ØC mm 3-10 5-13 8-17 L mm 8 8 8 SW1 mm 20 24 29 SW2 mm 20 24 29 H mm 35.5 36 43 RAL7001 Silver Grey RAL7035 Light Grey RAL9005 Jet Black 50.616 PA/R 50.620 PA/R 50.625 PA/R 50.616 PA/R7035 50.620 PA/R7035 50.625 PA/R7035 50.616 PA/RSW 50.620 PA/RSW 50.625 PA/RSW DLN16G DLN20G DLN25G DLN16G7035 DLN20G7035 DLN25G7035 DLN16B DLN20B DLN25B Flanged Locknuts M16 M20 M25 Thickness mm 7 7 8 Diameter (max) mm 22.5 26.6 32.5 Tel :- Web :- www.hylec-apl.com 01933 234400 Fax :01933 234411 Email :- sales@hylec-apl.com Making The Right Connections Hylec-APL glands.doc
50.620 PA/R7035 价格&库存
很抱歉,暂时无法提供与“50.620 PA/R7035”相匹配的价格&库存,您可以联系我们找货
