HYKS-05712PP
HYKS-05712PP
    HYLEC
HYKS-05712PP 数据手册
Kwik Snap Terminal blocks A range of VDE approved 12 pole terminal blocks in 24A, 32A, 57A and 76A options. All products are manufactured from white UL94-V2 grade Polypropylene, have a formed zinc plated steel insert and feature ‘Kwik-Snap’ pole removal without tools. However, although the blocks can easily be divided into the required number of terminals, the pole dividers are still strong enough to support screws for terminal block assembly. Features & Benefits:     Easy, Kwik & clean break – No tools required Pole dividers support screws for assembly VDE approved & rated to T85-110 Formed, zinc plated steel insert Specification:Ambient Termperature: T85-T110 C All products comply with IEC/EN60998-1,60998-2-1 Hylec-APL Part Number Volts (V) HYKS-02412PP 450 HYKS-03212PP Amps (A) Max Wiring Capacity (Sq. mm) Height Width Length Pitch 24 4 12.2 93.5 17.8 8 450 32 6 14 116.5 20 10 HYKS-05712PP 450 57 10 16.3 139.3 23.4 12 HYKS-07612PP 750 76 16 20.9 169.5 27.7 14.5 VDE / IECrated
HYKS-05712PP 价格&库存
很抱歉,暂时无法提供与“HYKS-05712PP”相匹配的价格&库存,您可以联系我们找货
