50.616 PA/4X2.3
50.616 PA/4X2.3
    HYLEC
50.616 PA/4X2.3 数据手册
PERFECT cable gland 50.6xx PAzzzz/zXz Configuration Dome nut Polyamide PA6 V-2 Sealing insert Evoprene TPE Gland body Polyamide PA6 V-2 Connecting thread metric, as per EN 60423 Properties • Temperature range sealing insert for the installation of several single cables -20°C +100°C Protection grade IP65 if diameters of bore holes in the sealing insert and cable diameters are almost identical Comment please indicate required sealing insert, e.g. 50.612 PA/4x2 sealing inserts - see under accessoiries - series WJ-DM xx/zXz Features RAL 9005 Connecting thread standard length A L SW1 SW2 H mm mm mm mm Piece M12x1,5 8 15 15 31 100 50.612PA/SW/zXz M16x1,5 8 20 20 35,5 100 50.616PA/SW/zXz M20x1,5 8 24 24 36 100 50.620PA/SW/zXz M25x1,5 8 29 29 43 50 50.625PA/SW/zXz M32x1,5 10 36 36 50 25 50.632PA/SW/zXz M40x1,5 10 46 46 51 10 50.640PA/SW/zXz RAL 7035 Connecting thread standard length www.hylec-apl.com Part No. A L SW1 SW2 H Part No. mm mm mm mm Piece M12x1,5 8 15 15 31 100 50612PA7035/zXz M16x1,5 8 20 20 35,5 100 50616PA7035/zXz M20x1,5 8 24 24 36 100 50620PA7035/zXz M25x1,5 8 29 29 43 50 50625PA7035/zXz M32x1,5 10 36 36 50 25 50632PA7035/zXz M40x1,5 10 46 46 51 10 50640PA7035/zXz RAL 7001 Connecting thread standard length A L SW1 SW2 H mm mm mm mm Piece M12x1,5 8 15 15 31 100 50.612 PA/zXz M16x1,5 8 20 20 35,5 100 50.616 PA/zXz M20x1,5 8 24 24 36 100 50.620 PA/zXz M25x1,5 8 29 29 43 50 50.625 PA/zXz M32x1,5 10 36 36 50 25 50.632 PA/zXz M40x1,5 10 46 46 51 10 50.640 PA/zXz www.hylec-apl.com Part No.
50.616 PA/4X2.3 价格&库存
很抱歉,暂时无法提供与“50.616 PA/4X2.3”相匹配的价格&库存,您可以联系我们找货
