5625////1121
5625////1121
    HYLEC
5625////1121 数据手册
5625////1121 Paguro gel connector junction box black, 4 cable entry 6.5-12mm cable with 3 pole terminal block SPECIFICATION Cable Entries Number of Poles Terminal Type Body Material Colour Max Conductor Size (Sq mm) Max Current (A) Max Voltage (V) Minimum Temp Rating °C IP Rating Max Temp Rating °C Minimum Cable Diameter (mm) Maximum Cable Diameter (mm) Depth Fixing System Gel Material Length (mm) Width (mm) 4 3 Screw - wp Nylon PA66-RV V0 Black 4 16 250 -30 68 130 6.5 12 24 Cable Sealing bi-component syliconic gel 95-105 depending on fitting of cable adapters 44 DISTRIBUTORS Tel: 01933 234400 Fax: 01933 234411 Email: sales@hylec-apl.com Web: www.hylec-apl.com
5625////1121 价格&库存
很抱歉,暂时无法提供与“5625////1121”相匹配的价格&库存,您可以联系我们找货
