HY-433-FV-12
HY-433-FV-12
    HYLEC
    HYLEC - HY-433-FV-12 - Panel Mount Barrier Terminal Block, 2 Row, 12 Ways, 10 mm, 32 A
HY-433-FV-12 数据手册
HY433/12 FV 12 pole red-brown polyamide PA6.6, with 25% glass fibre reinforced pillar terminal block 10mm pitch 32a 450v SPECIFICATION Number of Poles Terminal Material Body Material Colour Glow Wire Resistance Test Temp Max Conductor Size (Sq mm) Max Current (A) Max Voltage (V) Working Temperature Pitch (mm) Height (mm) Width (mm) Length (mm) Diameter (mm) Terminal Screw Material Tel: 01933 234400 12 OT58 nickel plated Polyamide PA6.6, with 25% glass fibre reinforced Red-brown GWT750°C in 2 sec (EN60695-2-11) 4 32 450 150 10 17.6 20.3 117.2 3.2 White zinc plated steel Fax: 01933 234411 Email: sales@hylec-apl.com Web: www.hylec-apl.com
HY-433-FV-12 价格&库存
很抱歉,暂时无法提供与“HY-433-FV-12”相匹配的价格&库存,您可以联系我们找货
