DEBOX SM40
DEBOX SM40
    HYLEC
    HYLEC - DEBOX SM40 - ELECTRICAL JUNCTION BOX, 4WAY, WHITE
DEBOX SM40 数据手册
Technical Information: Debox SM40 OVERVIEW Save time & money with Debox SM40, the smallest 4-pole junction box. Debox is a range of innovative junction boxes designed to save you both time and money on every installation. Each Debox is supplied with a 4-pole connector block. Featuring everything you need immediately to hand, not only does Debox reduce time on-site, it also offers greater flexibility. Debox can accommodate 2, 3 & 4 conductors in round or flat profile cable for ring main lighting, LED lighting or power. Debox SM40 is a registered design. DIMENSIONS 80mm L x 35mmW x 25mm H W FEATURES THE SMALLEST 4-POLE JUNCTION BOX L H GENEROUS CABLE MANAGEMENT SPACE SUPPLIED WITH 4-POLE TERMINAL BLOCK SCREWLESS CABLE CLAMPS FLAME RETARDANT TO UL94V-0 HOUSING EN 60598-1 (GWT 650 °C) EXTERNAL DETACHABLE FIXING LUGS EN 60670-22 PULL TEST REGISTERED DESIGN: 008190920 A Brand of Hylec-APL Ltd. FEATURES MAXIMUM 24 AMPS MULTIPLE FIXING OPTIONS FLAME RETARDANT HOUSING TOOL-LESS CABLE CLAMPS 4 POLE 24A TERMINAL BLOCK SPARE LOCKING CLIP LOCKING CLIP Debox SM40 Product Code DEKSB-006 Colour H (mm) W (mm) L (mm) 25 35 80 White Terminal Block Pole Body Material Insert Material 4-pole Polypropylene Steel Max Conductor Size (mm²) Maximum Current (A) Temp Rating 4 24 ­20°C to +85°C ALSO AVAILABLE Debox S As part of the Debox in-line junction box range, we also have the Debox S. Manufactured with identical housing as the Debox SL, the Debox S is supplied with a 24A UL/VDE approved 4-pole terminal block. Product Code DEKSB-002 Colour White H (mm) W (mm) L (mm) 28.5 48 97 Terminal Block Pole Body Material Insert Material 4-pole Polypropylene Steel Max Conductor Size (mm²) Maximum Current (A) Temp Rating 4 24 ­20°C to +85°C Debox SL As part of the Debox in-line junction box range, Debox SL can be assembled in less than 20 seconds without compromising quality. Each Debox is supplied with a 4-pole connector block. Featuring everything you need immediately to hand, not only does Debox reduce time on-site, it also offers greater flexibility. Debox can accommodate 2, 3 & 4 conductors in round or flat profile cable for ring main lighting, LED lighting or power. Product Code DEKSB-003 Colour White H (mm) W (mm) L (mm) 28.5 48 97 Terminal Block Max Conductor Size (mm²) Pole Body Material Insert Material Min Max 4-pole Polypropylene Steel 0.5 2.5 Maximum Current (A) Temp Rating 18 ­20°C to +85°C Debox SL2 Debox SL2 is the smallest junction box with five poles on the market and the only product supplied complete with 5 screwless terminals: each individual 32A lever connector can take up to three conductors. Debox SL2 saves valuable time and makes installation easier for smaller and larger internal wiring jobs, as everything needed is supplied with the box and there is no need to use a screwdriver to securely join wires and mount the box itself. Product Code DB00770/S Colour White H (mm) W (mm) L (mm) 35 47 107 Terminal Block Max Conductor Size (mm²) Pole Body Material Insert Material Min Max 5-pole Polypropylene Steel 0.25 4.0 MAKING THE RIGHT CONNECTIONS WWW.HYLEC-APL.COM | SALES@HYLEC-APL.COM | 01933 234400 Maximum Current (A) Temp Rating 32 ­20°C to +85°C
DEBOX SM40 价格&库存
很抱歉,暂时无法提供与“DEBOX SM40”相匹配的价格&库存,您可以联系我们找货
