PERFECT cable gland
50.6xx ES
Configuration
Dome nut
Stainless steel 1.4305
Lamellar insert
Polyamide PA6 V-2
Sealing ring
Polychloroprene-Nitrile rubber CR/NBR
Gland body
O-ring
Nitrile rubber
Connecting thread
metric, as per EN 60423
Properties
Temperature range
integrated anchorage
protection against twisting,
wide sealing and clamping
range
easy-to-install
-20°C
+100°C
Protection grade
IP68
IP69*K
Test standard
UL 514B
UL / CSA-File
E140310
GL T.A. Certificate
44 608 - 07 HH
Comment
details about tests - see annex, with
Viton-sealing ring and Viton-O-ring on
request
Features
Connecting thread standard length
A
ØC
L
SW1
SW2
H
mm
mm
mm
mm
mm
Piece
M12x1,5
3-6
5
14
14
25
50
50.612 ES
M16x1,5
5-9
5
17
17
30
50
50.616 ES
M20x1,5
9 - 13
6
22
22
33,5
50
50.620 ES
M25x1,5
11 - 16
7
27
27
36,5
50
50.625 ES
M32x1,5
14 - 21
8
34
34
38
25
50.632 ES
M40x1,5
19 - 27
8
43
43
41
10
50.640 ES
M50x1,5
24 - 35
9
55
55
49,5
5
50.650 ES
M63x1,5
32 - 42
10
65
65
52,5
5
50.663 ES
*IP69K tested for M12 - M25, M50, M63
www.hylec-apl.com
Part No.
很抱歉,暂时无法提供与“50.625 ES”相匹配的价格&库存,您可以联系我们找货
