5633/86
5633/86
    HYLEC
5633/86 数据手册
5633//////86 Minature Paguro gel connector junction box grey, 2 cable entry 8-10mm with 3 pole terminal block SPECIFICATION Cable Entries Number of Poles Terminal Type Body Material Colour IP Rating Max Conductor Size (Sq mm) Max Current (A) Max Voltage (V) Minimum Temp Rating °C Maximum Temp Rating °C Minimum Cable Diameter (mm) Maximum Cable Diameter (mm) Depth (mm) Fixing System Gel Material Length (mm) Width (mm) 2 3 Screw - wp Nylon PA66-RV Grey 68 2.5 16 250 -30 130 8 10 (c) 29.5 Cable Sealing bi-component syliconic gel (A) 38 (B) 42.5 DISTRIBUTORS Tel: 01933 234400 Fax: 01933 234411 Email: sales@hylec-apl.com Web: www.hylec-apl.com
5633/86 价格&库存
很抱歉,暂时无法提供与“5633/86”相匹配的价格&库存,您可以联系我们找货
