DEBOX SL
DEBOX SL
    HYLEC
    HYLEC - DEBOX SL - Junction Box, Terminal Block, 4, 16 A, IP20, Hylec - Debox
DEBOX SL 数据手册
Technical Information: Debox SL OVERVIEW The all-in-one compliant in-line junction box Save time & money with Debox… Installs in as little as 20 seconds! Debox is a range of innovative junction boxes designed to save you both time and money on every installation. Debox SL can be assembled in less than 20 seconds without compromising quality. Each Debox is supplied with a 4-pole connector block. Featuring everything you need immediately to hand, not only does Debox reduce time on-site, it also offers greater flexibility. Debox can accommodate 2, 3 & 4 conductors in round or flat profile cable for ring main lighting, LED lighting or power. Debox is a registered design. DIMENSIONS FEATURES 28.5mm (H) x 50mm (W) x 97mm (L) SAVE TIME & MONEY 100% TOOL-LESS BOX ASSEMBLY W L SUPPLIED WITH 16A 4-POLE TERMINAL BLOCK FLAME RETARDANT UL94V-0 HOUSING H EN60670-22 (PULL TEST) EN60598-1 (GLOW WIRE TEST 650°C) COMPLETE WITH LOCKING CLIP PRE-CUT LEAD IN CABLE ENTRY MAINTENANCE FREE A Brand of Hylec-APL Ltd. FEATURES FEATURES PUSH FIT TERMINAL BLOCK MULTIPLE FIXING OPTIONS CABLE CLAMPS FLAME RETARDANT HOUSING LOCKING CLIP Debox SL Product Code DEKSB-003 Colour White H (mm) W (mm) L (mm) 28.5 48 97 Terminal Block Max Conductor Size (mm²) Pole Body Material Insert Material Min Max 4-pole Polypropylene Steel 0.5 2.5 Maximum Current (A) Temp Rating 18 ­20°C to +85°C ALSO AVAILABLE Debox S As part of the Debox in-line junction box range, we also have the Debox S. Manufactured with identical housing, the Debox S is supplied with a 24A UL/VDE approved 4-pole terminal block. Debox S Product Code DEKSB-002 Colour White H (mm) W (mm) L (mm) 28.5 48 97 Terminal Block Pole Body Material Insert Material 4-pole Polypropylene Steel Max Conductor Size (mm²) Maximum Current (A) Temp Rating 4 24 ­20°C to +85°C MAKING THE RIGHT CONNECTIONS WWW.HYLEC-APL.COM | SALES@HYLEC-APL.COM | 01933 234400
DEBOX SL 价格&库存
很抱歉,暂时无法提供与“DEBOX SL”相匹配的价格&库存,您可以联系我们找货
