DED015
DED015
    HYLEC
    HYLEC - DED015 - IP65 ABS Wall Mount Enclosure with Transparent Door - 400x300x220mm
DED015 数据手册
NEW! Kwik Fix Cable Gland DOOR ENCLOSURES & ACCESSORIES ROBUST, VERSATILE, All-WEATHER & SEALED to IP65 DOOR ENCLOSURES ENCLOSURES Door Enclosures with Solid & Transparent Doors CONTROL STATIONS SWITCHES DE DOOR ENCLOSURES ACCESSORIES DE Door Enclosures are made from ABS HB material to IP65 standard and come complete with a steel back plate, mounting wall brackets and lockable key. They come in eight sizes and can be used in various environments including seaside conditions, dry dusty environments and in heavy humidity. Features: • Designed to meet protection and combustible standards IP65 and IK08 • Available in eight sizes. Two more coming later in 2011 • Supplied in grey (RAL 7035) with solid door and base unit or grey base with transparent polycarbonate door • Come complete with steel back plate • Wall thickness on the range is 3 – 3.5mm • Made from UL approved ABS-HB flame retardant plastic E ENCLOSURES WITH SOLID DOOR CODE DED001 DED002 DED004 DED005 DED006 DED007 DED008 DED010 2 SIZE (mm) 200 250 300 300 350 400 400 500 x x x x x x x x 300 350 400 400 500 500 600 700 x x x x x x x x 130 150 170 220 190 240 200 250 • Comply with the following standards: EN 60439-1, EN 62208, CEI 23-48, CEI 23-49 • Perform within a temperature range of –20° to +85° • Suitable for use in sea salt air conditions and dry dust environments • Accessories include a unique patented Kwik Fix Cable Gland with snap in single component mounting (no separate nut and thread) Applications: • Marine • Automation • Telecommunication • Gas Industry • Lifts and Elevators • Heating and Ventilating E DESCRIPTION Solid Solid Solid Solid Solid Solid Solid Solid Door Door Door Door Door Door Door Door • Panel Building • Lighting • Construction • Machinery Industry • Cranes ENCLOSURES WITH TRANSPARENT DOOR CODE DED011 DED012 DED014 DED015 DED016 DED017 DED018 DED020 SIZE (mm) 200 250 300 300 350 400 400 500 x x x x x x x x 300 350 400 400 500 500 600 700 x x x x x x x x 130 150 170 220 190 240 200 250 DESCRIPTION Transparent Transparent Transparent Transparent Transparent Transparent Transparent Transparent Door Door Door Door Door Door Door Door www.decontrols.co.uk DOOR ENCLOSURES ENCLOSURES Door Enclosures – Features, Dimensions & Products CONTROL STATIONS Galvanised Steel Mounting Plate Sealed to IP65 Galvanised Steel Back Mounting Plate Robust Housing Functional Details Lockable Key DIMENSIONS AND PRODUCT CODES SIZE (mm) 250x350x150 300x400x170 300x400x220 350x500x190 400x500x240 400x600x200 500x700x250 DED001 DED011 DED002 DED012 DED004 DED014 DED005 DED015 DED006 DED016 DED007 DED017 DED008 DED018 DED010 DED020 200 250 300 300 350 400 400 500 B 300 350 400 400 500 500 600 700 C 143 195 245 241 291 34 341 443.5 D 250 300 357 348 448 447 548 650.5 E 112 162 212 212 262 312 312 412 F 238 288 338 338 438 438 538 638 G 130 180 230 230 280 330 330 430 H 222 272 322 322 422 422 522 622 I 130 150 170 220 190 240 200 250 J 119 139 159 209 179 229 189 239 K 127 177 227 227 277 327 327 427 L 177 227 277 277 277 277 477 577 M 225 275 324.5 324.5 374.5 425 424.5 524.5 N 227 277 327 326.5 426.5 427 526.5 626.5 O 150.5 200 250 250.5 300.5 350.5 350.5 450.5 P 346 391 441 441 541 541 641 741 www.decontrols.co.uk ACCESSORIES A SWITCHES ILLUSTRATIONS REF. CODE BELOW 200x300x130 3
DED015 价格&库存
很抱歉,暂时无法提供与“DED015”相匹配的价格&库存,您可以联系我们找货
