500830
500830
    MUXLAB
    MUXLAB - 500830 - HDMI 2.0/3G-SDI SIGNAL GENERATOR, 2W
500830 数据手册
HDMI 2.0/3G-SDI Signal Generator 500830 Overview: This Signal Generator is a portable test tool that is able to generate SD/HD/3G SDI and HDMI 2.0 test patterns in a full range of resolutions up to 4K@ 60Hz (4:4:4). The unit assists users in validating the capabilities and proper operation of their sink devices. The user may select from various test pattern, resolutions, refresh rates, color spaces and other related parameters. When used with the 500831 Signal Analyzer, a useful set of cable connectivity/quality tests, and device compatibility tests can be performed to help identify problems. The device is an exceptional tool at an attractive price for any AV engineer/developer, Integrator and installer. The Signal Generator is a portable device which can be used anytime you need it and anywhere, making it an invaluable tool. The unit supports an internal rechargeable Lithium-ion battery, allowing the device to be operated autonomously for up to 5 hours per charge. Applications: Key Features:              Testing AV sink devices  Testing AV transmission infrastructure Portable Signal Generator – for autonomous operation anytime and anywhere! Supports up to 5 hours of operation on a single charge via an internal rechargeable Lithium-ion battery Supports HDMI up to 4K/60 & 3D, and 3G-SDI Supports RGB4:4:4, YUV4:2:2, YUV4:2:0 & Deep Color Supports 33 preset patterns & 32 preset resolutions 3” LCD panel for pattern preview & menu settings Supports 7 audio sample rates Supports HDCP on/off, for testing HDCP 2.2 & 1.4 Supports EDID management Locally or remotely managed via RS232 or USB Supports an RS232 cascade for management Free Windows management software Specifications Environment HDMI 2.0 and 3G-SDI Devices HDMI Signal Support SDI Signal Support HDCP Support & Control Video Bandwidth Color Depth Color Space Resolution/Refresh Rate Presets Testing projectors, monitors, and TV displays. Plus cable infrastructure when paired with 500831. User Defined Resolutions/Refresh Rates Supported Patterns Audio Bit Depth Audio Sample Rate Vertical Frequency Range Connectors Power Source Power Consumption Temperature Enclosure Dimensions Weight Compliance Warranty Order Information Companion Product (sold separately) © MuxLab Inc. 2017 Up to HDMI 2.0/DVI SD-SDI, HD-SDI and 3G-SDI Supports HDCP 2.2 and 1.4, with On/Off control. Up to 18.0GHz (6.0GHz per channel). 24bits,30bits,36 bits,48bits RGB444,YUV444,YUV422,YUV420 (HDMI 2.0 only) 32 preset resolutions: 4K/30, 4K/25, 4K/24, HDMI2.0 4K/60, HDMI2.0 4K/60, 720P-3D, 1080P-3D, … Auto modes: one auto mode. 10 configurable presets. 33 preset patterns (32 2D pattern and one 3D pattern) 16bit,20bit,24bit 32K,44K,48K,88K,96K,176K,192K ≤ 120Hz One (1) HDMI connector for HDMI video-out. One SDI (BNC) connector for SDI video-out. One (1) S/PDIF connector for digital audio-in. One (1) 3.5mm connector for analog audio-in. One (1) RS232 DB9 connector for management. One (1) RS232 terminal block for cascading management port. One (1) USB connector for management One (1) 2.1mm locking power connector. One (1) 110/240VAC to 5VDC @ 1A power supply, with interchangeable blades for US, UK and EU. One (1) built-in (non-serviceable) rechargeable Lithium-ion battery supporting up to 5 hours of usage per charge. (Unit supports a power switch on rear. Battery charge duration may vary.) 2W Operating: 0° to 40°C Storage: -20° to 85°C Humidity: Up to 95% non-condensing Metal 6.38” x 1.73” x 3.74” (162mm x 44mm x 95mm) 1.14lbs (0.52kg) Regulatory: FCC, CE, RoHS Flammability: 94V0 2 years 500830 HDMI 2.0/3G-SDI Signal Generator (UPC: 627699008300). 500831 HDMI 2.0/3G-SDI Signal Analyzer. HDMI 2.0/3G-SDI Signal Generator HDMI 2.0/3G-SDI Signal Generator 500830 _____________________________________________________________________________________________ Typical Application Signal Generator Alone: Signal Generator & Analyzer Combo: © MuxLab Inc. 2017 HDMI 2.0/3G-SDI Signal Generator MuxLab Inc. 8495 Dalton Road, Mount Royal, Quebec, Canada, H4T 1V5 Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free:1 877 689-5228 E-mail: videoease@muxlab.com www.muxlab.com
500830
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:共有6个引脚,分别为1脚发光二极管阳极,2脚发光二极管阴极,3脚光敏三极管集电极,4脚光敏三极管发射极,5脚光敏三极管基极,6脚光敏三极管集电极。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
500830 价格&库存
很抱歉,暂时无法提供与“500830”相匹配的价格&库存,您可以联系我们找货
