500000
500000
    MUXLAB
500000 数据手册
CCTV Balun 500000, 500000R, 500009, 500009-2PK, 500031 __________________________________________________________________________________________ Overview The CCTV Balun allows a single CCTV video signal to be transmitted via cost-effective unshielded twisted pair (UTP) cable. Used in pairs, the CCTV Balun eliminates costly and bulky coaxial cable, allowing CCTV security and surveillance equipment to be connected using standard structured cabling techniques for neater and more streamlined cabling. The CCTV Balun is available in two models; CCTV Screw Terminal Balun (500009) and CCTV Modular Balun (500000, 500031). Both models may be used interchangeably. Benefits Cost savings - eliminate costly coaxial cable Quicker moves, adds and changes Neater wiring Specifications Environment Devices Transmission Bandwidth Maximum Input Insertion Loss Return Loss Common Mode Rejection Max. Distance Colour Max. Distance Black & White Cable – UTP Cable – BNC Connectors Reverse polarity sensitive Features Up to 2,200 feet (670m) via Cat 5E/6 UTP* BNC (500000) or RCA (500031) option Cable strain relief (500009) Compact design Low return loss * Less distance may result with DVR/IP encoders. Typical: 1,000 to 1,500 ft via Cat5E/6 Close-Circuit TV (CCTV) equipment for security and surveillance. CCTV cameras, monitors, switchers, sequencers, multiplexers, digital video recorders (DVR), IP camera servers and other CCTV equipment. Transparent to the user. Video: DC to 8 MHz. 1.1Vp-p Less than 2 dB per pair over the frequency range from DC to 8 MHz Greater than 15 dB over the frequency range from DC to 8 MHz Greater than 40 dB @ 8 MHz Cat 3 –1200 ft; Cat 5 or higher – 2200 ft.* * Less distance may result with DVR equipment. Typical: 1,000 to 1,500 ft via Cat5 Cat 3 –1500 ft; Cat 5/6 – 2500 ft 24 gauge or lower solid copper twisted pair wire impedance: 100 ohms at 1 MHz Maximum capacitance: 20 pf/foot. Attenuation: 6.6 dB/1000 ft at 1 MHz Impedance: 75 ohms at 1 MHz (RG59/U). 500000, 500031: RJ45 Pins R7 T8 500000R: RJ45 Pins R8 T7 (pin compatible with 500022, 500024, 500130, 500131, 500133) 500009: Two (2) screw terminals Input: 75 ohms (BNC) Output: 100 ohms (RJ45) Operating: 0º to 55º C. Storage:-20º to 85º C. Humidity: up to 95% ABS fire retardant plastic 500000, 500031: 1.75” x .75” x 1.00” (4.44cm x 1.9cm x 2.54cm) 500009: 2.30” x 0.62” x 0.62” (5.8cm x 1.57cm x 1.57cm) 1.5 oz (42.5gm) FCC Class A, CE, RoHS Lifetime 500000 CCTV Modular BNC Balun, R7T8 500000R CCTV Modular BNC Balun, R8T7 500009 CCTV Screw Terminal Balun 500009-2PK CCTV Screw Terminal Balun, Retail 2-Pack 500031 CCTV Modular RCA Balun. R7T8 Impedance Temperature Enclosure Dimensions Weight Regulatory Warranty Order Information © MuxLab Inc. 2002-2010 Rev C Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free: 877 689-5228 E-mail: videoease@muxlab.com URL:www.muxlab.com CCTV Balun CCTV Balun 500000, 500000R, 500009, 500009-2PK, 500031 __________________________________________________________________________________________ Typical Applications © MuxLab Inc. 2002-2010 Rev C Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free: 877 689-5228 E-mail: videoease@muxlab.com URL:www.muxlab.com CCTV Balun
500000 价格&库存
很抱歉,暂时无法提供与“500000”相匹配的价格&库存,您可以联系我们找货
